Results 1 to 7 of 7
Thread: Temperature sensors gone wild
    Nov 2009
    Katy, TX
    94
    Hello everyone: Today I woke up to do my weekly routine on the pool (chemistry tests, brushing, and equipment inspection), to find my temperature sensors giving wild readings...I reset the panel, performed a self-test and lastly, changed the batteries in the remote (just in case) all of these to no avail.
    Has anyone else gone through 2 sensors gone bad at the same time? Is there another way to test?
    replies are most welcome...
    serge
    Inground with 7x7 spa (spillover)
    20k gal plaster (sunstone)
    pentair 3/4 hp (filter), 1 hp (spa), 1/2 hp (features)
    cartridge filter
    SWCG IC-40
    Polaris Platinum (with booster)
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Re: Temperature sensors gone wild
    I have had a rash of temp sensors lately (Pentair).
    What brand system do you have? And which two sensors went out at once?
    Factory Warranty Station for:
    Nov 2009
    Katy, TX
    94
    Pentair as well...both, pool water and air temp sensors.
    cartridge filter
    SWCG IC-40
    Oct 2007
    Valrico, FL
    542
    You might have some bad connections. Remove and re-tighten the sensor wires. If you have a multi-meter, measure the resistance of the sensors (disconnected from the controller). Should be stable, less than 10K ohms.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    Pisces's Avatar
    Jun 2008
    League City, Texas
    273
    Our year and a half year old Pentair temp sensor went out 4 weeks ago...same symptoms. We troubleshot it, and ended up buying a new one locally and installing it ourselves. $60..although we could have ordered one for almost half that, just didn't want to wait as we were having company that weekend and needed a quick fix. Pineloch Pools in Clear Lake had the sensor.
    7,000 gal. IG gunite, SWG, PebbleSheen interior finish-Aqua Blue, 8' vanishing edge raised 16-jet overspill spa, 2 12" waterfalls, tan shelf with bubbler.
    Pentair equipment: Easy Touch 8, Intellichlor IC-40, Intelliflo VF 3050, 2.5 hp Whisperflo spa pump, 1 hp Whisperflo water feature pump, Quad 100 DE filter, Master Temp 400 heater, Legend Platinum Cleaner (3/4 hp pump). Autofill, TF-100 Test Kit w/salt and borate strips.
    Pisces Pool Build
    Nov 2009
    Katy, TX
    94
    thanks all for your comments...PB is servicing as the equipment is under warranty still...will update with diagnostic and solution when available
    cartridge filter
    SWCG IC-40
    Nov 2009
    Katy, TX
    94
    Update: water temp sensor had a crack in it and stopped working. Air sensor had no apparent damage, but was replaced anyway. Equipment under warranty, so no problems. PB is behind his work and we couldn't be more satisfied with his perfromance...
    cartridge filter
    SWCG IC-40
