Results 1 to 12 of 12
Thread: every time I vacuum my spa turns to muck.
    Im starting to think this pool with this house I bought is going to be a never ending money pit. I have put in all new filters in attempt to fix this problem, but yet when ever I vacuum my pool it seems like the filter cant keep up and just dumps all the dirt into the spa? The pool is a 15K inground with a attached spa, and a 320 sf clean and clear plus filter system. Any Ideas on what could be causing this.
    Here are my numbers as of late.
    FC-7
    CC-0
    ph-7.5
    ta-80
    ch-400
    cya-60
    Trying to figure out also what I need to adjust the water really irritates peoples eyes, any levels I could change to make the water better?
    22,544
    Re: every time I vacuum my spa turns to muck.
    Your numbers look good. I don't see anything that should be irritating. You could try adding a little salt to your water. That usually helps the feeling a little.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Odd. Can you post some pictures of your plumbing area?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Do you have any information from the previous owner, like if they used a robot to clean the pool? I am wondering if there is a blown gasket somewhere or if the filter is plumbed wrong.
    The online manual may have some information that will help you.
    Love TFP? Become a
    TFP Supporter!
    No robot that I know of. The previous owner had not lived in the house for 2 years. They had a pool company adding chemicals for 2 years, but never did any maintenance or cleaning. Pool was a mess but in the last month I have got it swimable again.
    Jul 2009
    Houston, Texas
    9,379
    How big is your pump and what is the normal operating pressure on the filter? Also looking at the plumbing again, there is a line labeled "cleaner", so they may have used a robotic cleaner in the past, especially if they had the same trouble when trying to vacuum the pool. Can you post a picture of the filter showing the inlet and outlet for the water? Also it looks kind of like a second filter in the same area.
    Love TFP? Become a
    TFP Supporter!
    1.5 hp around 10 psi with the valves set the way they are in the picture. When I go to heat only the spa up and close off the pool it jumps to 20- 25 psi.
    Jul 2009
    Houston, Texas
    9,379
    I have added info to my last 2 posts and I am not sure you saw it. I added a link to an online manual and a couple more questions about your set up. I'm not sure what the problem could be, but I am hoping the pool service guys will be able to trouble shoot this for you.
    Love TFP? Become a
    TFP Supporter!
    Oct 2009
    3,899
    So if you have the return set to both spa and pool, only the spa gets muck in it; no dirt coming out the pool returns? And it only happens in the spa when you're vacuuming?
    Quote Originally Posted by Melt In The Sun
    Yes that is correct. It does seem like it does get filtered out after an hour or so, just seems really weird that it does this. What I have been doing is after I vacuum I put the vacuum in the spa and let it sit and the dirt eventually goes away. Its almost like the skimmer return takes water and dumps it into the spa then it goes into the filter. Im wondering do I need to just shut off all the valves to the spa and only have the pool valves open when I am vacuuming? My local pool store guy told me it should not matter and he thought it was the filters and that's why I ended up getting new ones to see if that would work.
    Thanks for all the help I really appreciate it.
