Results 1 to 7 of 7
Thread: Winterizing kit of any use?
    I have seen from reading this forum that most people say they just balance water, shock and cover when temps are lower.
    I can't wait for weather that cold...I have to do it now to avoid tons of leaves and nuts from dropping into the pool. At least until I can have the offending trees taken down.
    I ask because when I got my safety cover they gave me a winterizing kit for free so I have it already.
    The only thing I think I might wanna add is the "non chlorine" oxidizer time release thingy. But not too sure what that is and wondering if anyone here knows.
    Oh there is one of those sponge things to absorb oils and such in there too...do those work?
    25k gal vinyl AquaRite T-15
    chessie6's Avatar
    East Hartford, Connecticut
    187
    Re: Winterizing kit of any use?
    MPS (potassium monopersulfate) is most likely what is in the time release thingy. I just read about this yesterday in my latest In the Swim catalogue and it says it robs the water of carbon dioxide which is a primary food for algae. MPS isn't a sanitizer; it's an oxidizer but I believe it doesn't have any effect on combined chlorine. If I happened to have one on hand, I'd put it in - what the heck, but I wouldn't buy it.
    The Winter Sorb: definitely needed; as the armies of earthworms and other critters slip under the pool cover with their bods slathered in sunscreen to take a free dip in the pool . . . well, for sure you have to have something to absorb those oils
    I'm glad you didn't purchase the kit!
    Best,
    Jan
    Summer: 19 x 37 Pacific Graphex IG modified oval, aztec marine vinyl liner, 24,000 gal, 3.5 feet to 8 feet, 1 hp Hayward C4025 Swim Clear 4-cartridge filter, 12.5% Liquid Pool Shock for sanitizing, 1 super wide mouth skimmer, 4 returns (2 therapy jets in steps), Hayward Heat Pro heat pump, non-curved pool slide, 6' jump board, 8 ml blue solar cover, TF-100 test kit, had pink algae in 2010 Winter: Hot Springs Vista Spa, 500 gallons.
    Dec 2009
    Central Massachusetts
    2,690
    Quote Originally Posted by chessie6
    Actually it does eat combined chlorine, somewhat. It's can be used to chew up CC when CC becomes high due to ammonia sources getting into the pool and there is lot of CC to get rid of. Of course plain old chlorine will do the same thing, but using a non chlorine oxidizer like MPS keeps the chlorine level lower and can be advantagous to use MPS. But, i wouldnt use it to close. Plain old bleach is what I would use.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Jun 2007
    New Jersey
    653
    The In the Swim kit actually works pretty well. I started using it in 2005 before I joined here. Unlike my summers were before BBB, my opening/closing routine has been perfect (now 5 for 5 clean, clear spring openings) so I have not had the courage to change. The Sorb thingy is a joke, though.
    It costs the same as two bottles of Algaecide 60 and I'd need at least one, so changing programs could save me at most $20. Criticize it all you want, but don't say it doesn't work.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    chessie6's Avatar
    187
    Gosh, I hate to mislead anyone - please accept my apologies for posting incorrect information about MPS. I do a lot of research on the internet and the information came from somewhere I thought was trustworthy.
    Dec 2009
    2,690
    No worries!
    I guess i should clarify a bit. MPS will eat monochloramines better than other CC's. I think what you saw is that it may not be as effective against other CC's. The benefit of MPS, in certain cases, is it actually oxidizes ammonia containing compounds or ammonia itself before they have a chance to combine with chlorine. So, if you get fertilizer in the pool, or CYA converted to ammonia, then MPS can be used to oxidize the ammonia. Normally, chlorine acts as a fine ooxidizer all by itself. The other issue to watch is that MPS will show up as CC on the CC test, so you can get a false high reading for CC if you use it.
    Dec 2009
    2,690
    edited:
    Duplicate post
