Thread: Sundek - any durability issues?
    Aug 2010
    New Caney, TX 77357
    184
    We are in the bidding phase of a new in-ground pool project. The new decking installed around the pool will meet up with our existing covered concrete patio. We have met with 2 builders so far and have 1 quote, waiting for the 2nd. The standard decking offering is pea gravel. We do not particularly care for the look of it and it's not comfortable to walk on. We have looked at having Sundek sprayed over the new decking and the existing patio and have a quote for same from the first PB we met with. The 2nd PB does not recommend Sundek and characterized it as not especially durable, subject to staining, chipping, etc. His recommendation would be polymer based overlay but that is over twice the cost of Sundek and would bust our budget.
    I have Googled the web searching for any discussions/issues with Sundek durability but I am coming up dry. For those that have had Sundek for several years (or any PBs that participate here) what is your experience?
    20K gal, inground with attached spa, pebblefina plaster (bella blue), flagstone coping, moss rock waterfall, Sundek - Indian wheat, (2) Jandy PHPM2.0 (filter pump and waterfall), Jandy DEV60 DE filter, Polaris 280 pool cleaner, Polaris Halcyon PB4-60Q booster pump, Polaris 1.5 HP Air Blower, (2) Jandy WaterColors LED lights, Jandy LXI400P Heater, Jandy AquaPure PLC1400 SWG, Jandy AquaLink RS PureLink Controller and PDA.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Sundek - any durability issues?
    Pea gravel for a deck!? Sounds awful; it would hurt, and you'd end up with all of it at the bottom of the pool after it stuck to your feet when you jumped in!
    I'm not real familiar with Sundek; I have Kool deck and it is crumbling terribly. I posted some photos here, and the verdict was "lousy too-thin installation". That was this spring, and it looks twice as bad now.
    Aug 2010
    New Caney, TX 77357
    184
    Sorry you had a bad experience with your Kool Deck. I've been told by some pool pros in the last couple days that Sundek is a good product if installed correctly. Also got feedback on a non-pool related message board from some owners that have had Sundek installed up to 20 years with no problems.
    Oh and it's not loose gravel like you're thinking (if you were serious). It's a concrete deck with gravel sprinkled on just after freshly poured concrete is troweled. Then they lightly wash around it so that it's exposed well. This is like an exposed aggregate finish on a driveway. The look is very "old school" and not something we really care for. Also walked on it and not real comfortable when you're barefoot
