Thread: Jandy Aqualink Dual Equipment Help
    Hi
    I'm building a pool and using a Jandy Aqualink Dual Equipment System with the latest Revision Q board and chip. I purchased the board and chip on ebay so I didn't get any instructions. Jandy's website only has details of Dual Equipment systems with the old 52 pin board.
    I plan to run solar so in accordance with the instructions on the website I ordered a Jandy 6996 freeze protection kit. This kit arrived today and consists of what appears to be a thermostat and a jumper which is used to bridge the terminals W1. Problem is that the latest boards to not appear to have the terminals W1. I assume that one of the dip switches has taken the place of this jumper.
    If anyone out there has Dual Equipment instructions for the latest board or knows how freeze protection works on these boards I would be most grateful.
    Thanks Michael
    22K 18x36 in ground concrete pool. Intelliflo VF, Hayward cartridge filter, Zodiac Tri salt chlorinator with pH control, Rola Chem oRP chlorine dosing. Polaris power stream and deck jets with separate Intelliflo VS. Heattseeker solar heating. Jandy Aqualink.
    South Central NJ
    3,192
    Re: Jandy Aqualink Dual Equipment Help
    Here's a link to the Power Center Installation manual in PDF format. I think you will see what you are looking for though it says Rev N. If not, you may need to contact Jandy directly and ask them for any Change Notes.
    Scott
    http://www.jandy.com/html/productsuppor ... %200.2.pdf
    Owner of - PoolGuyNJ LLC
    Thanks for the link unfortunately it is still lacking the information I needed.
    I contacted customer support who advised that that the new boards do not need the jumper. The freeze sensor works fine however the air temperature, now solar temperature, is not displayed on either the Touchlink or aquapalm. The service rep didn't know if this is normal for dual equipment systems with solar and is chasing up the product manager.
