Thread: How to pick a skimmer
    Hi,
    we're restoring an old pool inground cement pool that didn't have a skimmer. We figured that because part of one the walls has to be replaced due to a large crack, this would be the perfect time to add a skimmer. From what I understand, they get mounted through the form before the pouring of the wall and will need a bit of a cement/rebar reinforced shelf to tie into the wall. This tells me that this thing is pretty permanent.
    So are there any brands to stay away from? So far it's between a pentair s15 and Hayward(cement versions)
    Is the equalization attachment a good feature? this would be the second connection under the unit that gets directed as an inlet within the pool directly under the skimmer. (correct?)
    Also, if my pool wall is 6" thick, does the space between the face of the unit(where the weir closes) and the bucket have to be greater than 6"? Most aren't.
    I'm going to need a lot of reassurance with this project if anyone has the time for me: )
    Cement 12'x30', in the neighborhood of 50 years old. Restored, 1.5"plumbing, 1hp super pump 2, Hayward swim clear cartridge filter, Summit2.5t heater,Hayward SWG t-9 cell, Nexxus Blanco lights, pentair bermuda gunite skimmer.
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    Get a white one
    Dear Brownsburg,
    Although I cannot advise you at all on any of the points you asked about, I feel extremely strongly about skimmer color.
    Every pool I've ever taken care of in the past always happened to have a white skimmer. I thought all skimmers were white.
    When we did our renovation, skimmer color never crossed my mind. I was mortified to find black skimmers installed. They are creepy and scary to me. I never know what is going to be in there when I go to clean them out! Where I live, there are so many critters that get into the pool and are there for me to find, dead or alive, in the skimmers.
    It takes great bravery and long rubber gloves for me to pull out my baskets. I find everything in there with the leaves and pine straw: Huge dead bugs, frogs still alive, baby possoms , sNaKes! And then, the worst part is, with the basket out, I don't know what the heck else is in that horrible abyss! I can't tell if it is clean or still has something awful in it.
    *shudder*
    Lana
    23,600 gallon, refurbished 1960's inground concrete, Jandy sand filter w Jandy 2 hp variable speed pump, Pool Pilot Digital SWCG+Chemtrol 2100+CO2 tank; PebbleTec White Pearl with 10% Cobalt Blue Dark Beadcrete by Olympic Pool Plastering, Georgia. Taylor K-2006 Test Kit; Aqua Check Salt test; LaMotte borates test, and Jack's Magic Sequest test kit; SparklyPoolitis level: extremely high.
    Guest
    Re: How to pick a skimmer
    Look at the Swimquip U-3. It is the industry standard.
    Thanks.
    When installing the skimmer, during the pour, do I need to coat the skimmer with some sort of product or is it cement directly on plastic? I guess I'm wondering if the cement pour by itself will make it waterproof.
    Thanks
    Sorry, but in the end there was only one option available within a 200km radius.
    Pentair, Bermuda.
    So this is what I bought.
