Results 1 to 9 of 9
Thread: what the heck is the trick with the Ladder
    My husband and I have tried several times to install our A Frame ladder and can't seem to get it right. It a monster to get into the pool and just seems to wobblie. The fin thats on the back of the ladder keeps touching the wall of the pool and those stupid metal poles are a joke. I read the instructiions and we are going to try taking it out again and starting from scratch. Does anyone have any tricks or tips for the A frame ladder installs, up keep and what not??
    I looked all over the ladder and instruction and the only thing it says is its a Latham Plastics ladder.
    24ft Seaspray Evoluction ABG
    1.5hp Pentair Dyno
    22in Sandfilter
    AquaTrol SWG
    Milton, FL (NW Florida Panhandle just outside of Pensacola)
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: what the heck is the trick with the Ladder
    You may have to fill the side that goes in the pool with sand to weigh it down. Do you happen to have a pic?
    Jan 2010
    Central Valley, CA
    233
    LOL! At least I'm not the only one. I plan on using bricks in ziplocks to weight it down but haven't gotten back to it. I also need to get the right bolts to connect it to the top rails. Thing floated all over on me just trying to see if I had it set right.
    I've been using a step ladder on the outside to get in and out since it's just family swimming for now.
    Garden Leisure Voyager 12x24 AGP, 7500 Gallons, Hayward Power Flo Matrix 1 HP pump, dual speed, Hayward XStream Cartridge Filter, 120 GPM,
    we have the same one and even filled with water it's wobbley
    thanks
    gary
    24ft x 54" aquasphere mission agp, cartridge filter, 1.5 hp hayward, TF-100, BBB method, pool install July 2010
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Do you guys mean floaty or wobbly like a piece of junk filling with water won't help if it floating...try filling it with sand...the fill material should be heavier than the water it's sitting in.
    Jan 2010
    Central Valley, CA
    233
    I just need to fill mine with something heavy. I put it in the water to test where I wanted it and it floated so much I couldn't really test.
    Am I correct that it should straddle a post? I guess I need to take the cap off of that post so it will set level.
    I will take apic of it later today-
    It not that our ladder isn't heavy because dang it is. It takes two people with some arm power to get it in and out without killing yourself. The issue is I can't get it to set right on the bottom and the fin on the back wants to touch the wall of the pool. The those two junky poles that stay on the outside of the pool aren't great support for the ladder. After reading around I read that someone used 4x4's and sunk them into the ground to attach their ladder to to make it not want to rock around. The ladder is solid but moves to much. SO my husband thinks we should fill the outside poles with cement and then attach the ladder to it. Also how do you store the take off ladder? I thought it would just flip up and lock but no it doesn't and we have four small kids so I was thinking of chain locking it to the yard gate for safety. Then again I looked around and found some ladders online that had built in locks and what not. Does anyone have any info on those?? What do you do for safety of your ladder from little ones??
    1.5hp Pentair Dyno
    22in Sandfilter
    AquaTrol SWG
    Jun 2010
    San Antonio
    424
    This may not be applicable to your situation, if not I apologize for bringing it up. I would not want to lock a ladder in the up position. If someone fell in I would want them to have an easy way out of the pool.
    Larry in Texas
    Above ground 7,700 gallons, 19 inch sand filter ( 2 sq. ft.), Liquidator, and a WaterWay Hi-Flo Pump with an A.O. Smith 1 hp SF 1.0 motor.
    Sep 2010
    San Diego
    31
    What I did was run 14 guage plain white lamp wire around the pool's metal beam under the ladder on a 24'x12" ultra frame Intex pool. Then connect that to an "flush head" eye bolt that was drilled into and bolted down to the ladder's top step. Compression fittings under the ladder's top step hold the wire taught. With me sitting on the ladder to "compress" the ladder I then tightened the nut attached to the eye bolt until the ladder's legs expanded and the strain just barely started to bend the plastic top step. The top step is 4" above the metal beam so you can barely see the wire unless you are looking for it.
    Not perfectly stable like the ladders sunk into cement pools but 200% better than before.
    At least when you are at the top of the ladder it doesn't feel like it is going to fall over on you.
