Results 1 to 9 of 9
Thread: Two Questions Regarding Pool Construction
    Has anyone ever heard of the following construction techniques:
    1. Using blocks with concrete poured into them for wall material?
    2. Instead of using rebar and a bonding grid for deck material, just using the bonding grid (and no rebar)?
    Pentair WhisperFlo WFDS-4 - Pentair Tagelus TA 100D
    16x32 Vinyl Rectangle 3.5 to 8 ft deep - One skimmer, One dedicated suction, three returns - 2" PVC
    Poolvergnuegen Two Wheel Suction Cleaner - One Poolskim
    Inter-Fab T7 Diving Board w/Edgewater Assy - Four Pentair Deck Jets - Intermatic T10604R
    Circupool RJ45 - Taylor K-2006 Test Kit (purchased prior to learning of the TF-100, unfortunately)
    FinsUp's Avatar
    Jul 2009
    Michigan
    68
    Re: Two Questions Regarding Pool Construction
    Our pool was built in the summer of 2009 in Michigan. I can't speak to your first question, but as for the second our pool only has the bonding grid under a portion of the deck. You can see a picture of it in the photo I've attached below. The contractor used what's called fiber mesh in the concrete, which supposedly replaces the need for wire mesh or rebar throughout the slab. So far so good.
    32.6K Gallon 16x41x24 L-Shape Vinyl Inground by Fort Wayne Pools
    DE Filter, 1HP Pump, Sta-Rite 400,000 Btu Propane Heater, Pentair IC40 SWG
    One Wife - Three Kids - Two Dogs
    22,550
    In answer to your first question, take a look at this thread.
    Finsup, answered your second. Fibercrete's the way to go.
    Thanks a lot for the info guys.
    Guest
    I am going to assume this is for a liner pool. If it is for a plaster pool, then the answer is no.
    Just don't want to read a thread later about a plaster pool with cracks every so often in a random checkerboard pattern.....
    Yeah, this is the same technique used by one of the builders I have spoken with: Concrete poured into concrete blocks, and then fitted with a vinyl liner.
    The builder said his process was almost exactly the same as the link provided by Bama Rambler, maybe not quite so much rebar is used.
    Thanks again for the link Bama.
    Fiber refers to fiberglass added to the concrete mix correct? I also heard if rebar is used it needs to be up off the ground so when the cement is poured it is surrounded by the concrete. As apposed to pour on top of that is. Fins up if you don't mind who installed your pool in Michigan. We are in the process of interviewing/getting quotes from builders.
    22,550
    Not just fiberglass, but steel and plastic fibers are used as well.
    FinsUp's Avatar
    Jul 2009
    Michigan
    68
    Quote Originally Posted by msteff
    We went with Scheidel Pool out of Conklin, Michigan.
    Here's a link to their website: http://www.scheidelpools.com/
    BTW - Dave's much better at building pools then he is at keeping the website up to date I see.
