Thread: swamp monster and manual vacuuming
    Hello group,
    My pool seems to have gotten away from me and I am leaving for a month with a very green swamp. I read Jason's
    very thorough and informative post on swamps vs. oasis. I choose the oasis, I just can't fix it right now. Anyway,
    my question is this: Do I need to rely on the filter to clear out the dead algae, or can I use a manual vacuum
    cleaner straight out of the pool and not mess with my filter. I don't currently own a manual vacuum, but if
    that could save some work on the filter, I would consider getting one. Thanks again for having this forum.
    Mule
    Dark plaster in-ground, 25K gallons, Triton II sand fliter, Teledyne Laars Series 2 ESG heater, Polaris 280 cleaner,
    Circupool RJ45 SWCG, one skimmer doesn't work (any suggestions for snaking this or determining why it doesn't
    work?), using 12mil bubble wrap solar cover, Marquis 660 hot tub using liquid bleach.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: swamp monster and manual vacuuming
    I think you will need some type of cleaner, manual or otherwise. Much of the gunk will settle to the bottom and just won't stay in the water long enough for the filter to pick it up otherwise.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    The question is do you have a "waste" setting for your filter? If so then vacuuming to waste to remove dead algae is the way to go. Just be sure to keep an eye on the water level since it will go down quickly.
    Love TFP? Become a
    TFP Supporter!
    I do have a waste setting. Should I just get a simple manual vac with a hose, or is there one that is a little more complex and does a better job?
    thanks again for the responses. Mule
    Jul 2009
    Houston, Texas
    9,396
    For this manual is the way to go. Robots do not vacuum to waste and if they do not have a fine enough collection bag the algae will strain through. I don't see anything about your pump in your signature, but if it is big enough to circulate your water effectively then it is strong enough to suck up the dead algae. Keep in mind you are vacuuming to waste so if you borrow a bigger pump then you will loose water that much quicker. Slow and steady is the way to suck up most of the algae without stirring it up too much. If you try to go too fast the algae particles will be in suspension and the pool will become extremely cloudy.
    Love TFP? Become a
    TFP Supporter!
