Hey Norbert,
I'm in central mass with a mesh loop-loc.
First of all, dont close it until the middle of October or till the night temps hit the low 40's upper 30's. If you do that, the water temp will be down into the low 60's, usually. Just raise the chlorine to shock level for your CYA, and add some poly 60 algecide. I know some will say the poly may not be needed, but I add it. Open the pool around patriots day. The key to a clean pool with a mesh cover is later close, earlier open. I assume you got the newest mesh loop loc has. It's really tight. In fact, it takes several hours just to drain a moderate rain from the cover.
On the tension, you dont want it trampoline/drum tight. When there is no weight on the cover, you want the straps to be tight, the cover to sag very minimally, if at all. A bit of tension on the springs is ok, enough to keep the cover flat and basically level. The water level you want is between 12-18 inches below the top of the pool. That's generally an inch or 2 below the skimmer. The idea is that when you get a snow load, the cover will have enough give that it will rest on top of the water. If its too tight and/or the water is too low, the snow weight will be held only by the springs, or it will stretch too far to get to the top of the water, and the springs will get stretched and have to be replaced too quickly.
Watch the water level during the winter. If it gets higher than 12 inches, put a pump on the top step and pump water back out. You dont want it to get much higher than 12 inches. If you have canteliver coping, be extra sure the water level doesnt get too high. Ice can push the coping up and damage it.
