Thread: Title grout and tiles cracking?
    Okay this summer the pool chemistry has sucked. I know I need to drain but need to wait for another month for weather to cool down.
    Currently you can see lots of white buildup on the blue tiles by the waterline. I am assuming this is calcium buildup. BUT the strange thing is it appears to be eating away at the tile grout, as well as many of the tiles appears to be cracked right at the water line. Is this also calcium doing this?
    12,000 Gallon
    Hayward 2HP Pump
    Solar Panel
    TF-100 Kit
    Built 2004, bought Dec 2007
    BBB All the Way
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Title grout and tiles cracking?
    Calcium won't eat away grout or crack tiles; it just forms as a crust everywhere as you've seen. Cracked tiles at the waterline sounds like freeze damage to me, but I live in southern Arizona so my experience with winterization is rather...limited. Some pictures would help. Where are you located?
