Thread: Calcium test
    Calcium test
    With the current state of my pool I am unable to test the Calcium level with the TF100 test. The color turns clear before anything else. Is there a way to test a higher amount of calcium? like double the red drops? half the water?
    12,000 Gallon
    Hayward 2HP Pump
    Solar Panel
    TF-100 Kit
    Built 2004, bought Dec 2007
    BBB All the Way
    Re: Calcium test
    Quote Originally Posted by nitz369
    What happens if you continue adding reagent after the water turns clear?
    17,000 Gallon plaster pool. Hayward Perflex EC65 DE Filter. 3/4 HP Hayward Superpump converted to dual speed. CircuPool RJ45. Skimmer, floor drain, two returns.
    Re: Calcium test
    nothing, the most drops I have added is about 70 though.
    12,000 Gallon
    Hayward 2HP Pump
    Solar Panel
    TF-100 Kit
    BBB All the Way
    Guest
    Re: Calcium test
    Can you post your procedure and which reagents you used and in what order. Something is a miss?
    Re: Calcium test
    25ml water
    20 drops R-0010
    5 drops R0011L
    add R-0012 till turns blue.
    The R-0012 is clear solution so each drop dilutes to R-0011L to be just a little bit more clear. By about 60-70 drops it is almost completly clear and very hard to tell if it turned blue. this would say my calcium level is above 700, how can I test higher calcium?
    12,000 Gallon
    Hayward 2HP Pump
    Solar Panel
    TF-100 Kit
    BBB All the Way
    Guest
    Re: Calcium test
    Do you have some type of magnetic stirrer or agitator or are you shaking your sample with your hand?
    Try putting 2 drops of R0012 first, before you add the first 20 drops of R0010.
    Also, how many drops does it take before it goes from pink to purple?? or does it?
