Thread: LED Lighting Nexus Melody vs. Pentair Intellibright
    Aug 2010
    Jacksonville, FL
    23
    I am in the planning stage of building an IG free form pool. One builder is using the Nexus Melody. I am not to sure about them. The good thing is that I can get 3 for the Same price as one Intellibright, you can place them in a sun shelf. The negative is they are not a standard size. Not sure if the Nexus 1 1/2" size will be around in 5 or 10 years if the stop working.
    Marc
    Soon to be built: ~15,000 gallon in ground pool/spa Gunite with Marbletite Beach series finish, Pentair Intellitouch I7+3, Intellibrite LED lights, Sta Rite Intellipro VS 3050 pump, Star Rite PLM cartridge filter, IC40 SWG, Sta Rite Max E Therm 400K propane gas heater, Automatic water level
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: LED Lighting Nexus Melody vs. Pentair Intellibright
    If it were me, I would be very reluctant to go with something uncommon and oddly sized. I've been around the board a while and have never heard of Nexus Melody.
    Dec 2009
    Central Massachusetts
    2,690
    i'm with MITS. Anything non standard may be hard to replace. You cant go wrong with that Pentair light. I have about the same light only it's a Hayward Colorlogic. Either one of those are good choices.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Aug 2010
    Jacksonville, FL
    23
    Thanks I think I will stay with the standard size light
    Dec 2008
    82
    The latest is the "intellibrite 5G", in case you want the latest and greatest.
