Thread: Optimum TA level
    Jul 2010
    northern California
    235
    Optimum TA level
    I have been adding MA to reduce pH to 7.3 almost everyday. Meanwhile, TA was decreasing. I did the weekly testing today and it is at 60. Here is the rest of the test:
    FC - 6
    CC - 0
    pH - 7.6 (targeted at 7.3 daily)
    TA - 60
    CH - 340
    CYA - 70
    Should I increase TA to 90?
    Thanks.
    IG pebbletec pool: size of pool: 27,000 gal; filter: cartridge - Hayward Superstar Clear; pump size: 1.5 HP; TF 100 Test kit - got it on 7-29-10; The Pool Cleaner-4-wheel suction model; Pool calculator: http://www.poolcalculator.com/; bleach calc: http://troublefreepool.com/files/BleachCalc262.exe
    22,550
    Re: Optimum TA level
    Why are you wanting your pH at exactly 7.3?
    Most people let the pH settle where it likes to be and as long as it's between 7.2 and 7.8 it's fine.
    I'd suggest leaving it alone for a few days and see where it likes to stay at.
    Obviously, if it gets above 7.8 you should adjust it down.
    Leave your TA alone for now.
    Feb 2008
    Denton, TX
    5,061
    Your TA will continue to decrease as long as you continue to add acid to the pool.
    As Bama suggested, you might consider backing off a bit and see if your pH can find a happy place somewhere between 7.2 and 7.8. Most pools do as long as the TA is not high and yours is not.
    Jul 2010
    northern California
    235
    I try to keep pH at 7.3 or 7.4 because it has been suggested to me to keep it around that level due to high CH and TA. TA was 120 a month ago. Now that it is much lower, maybe that was why pH kept wanting to remain between 7.5 and 7.8. I will leave it alone for now. Regarding TA at 60, it is not within the recommended range of 70 to 90. Will that be ok? Thanks.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Quote Originally Posted by kal2002
    My guess is yes. Test your fill water - it's probably pretty high in CH and TA. So the next time you add water, it will get back up.
    Maybe that's just where your pool wants to be. My pool seems to stabilize at 90. I can work,work,work at driving it down and in 2 days it will be back to 90. And then it will just sit there for weeks. I'll add acid to adjust pH every couple days, but TA just sits there.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    TA of 60 is fine for now...with High CH you do not want your water above PH of 7.8. Most pools settle in around the 7.4-7.7 area.
