Thread: Intex w/ SWG for 15 day vacay. What to do if power outage?
    Florida's Space Coast
    3
    We are going on vacation at the end of September for about 15 days. We have the Intex SWG & pump hooked up to a timer that turns the pump on, then the SWG turns on about an hour after that. I have done some searching on the board about what to do for vacations but I haven't noticed anyone mentioning what happens if there is a power outage.
    We have blips every single week where the whole house's power goes out for a second or two, sometimes multiple times a week. This has no affect on the pump but the SWG needs to be reprogrammed whenever this happens. We don't have anyone to come by to check on the pool for us . I'm just wondering what the steps we should take to be prepared for an outage. I really don't want to come home to a green pool as we fought algae this spring & it cost us a boat load of time & sanity to get it all worked out.
    Any help is appreciated.
    15'X48" Intex Frame - 4,400 gallons, with the standard craptacular pump/filter.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Re: Intex w/ SWG for 15 day vacay. What to do if power outage?
    I am assuming it is only the SWG that will need resetting and the pump will continue to work off the timer? If so then you could raise up the FC a little and use a floater with trichlor pucks to ensure some FC stays in the water.
    Also you could bump the pool up to shock level with liquid chlorine and adjust the SWG output to keep the FC close to shock level before you leave. If the power goes out odds are you will still have enough FC to prevent a full algae bloom.
    Love TFP? Become a
    TFP Supporter!
    22,542
    I'd suggest a small UPS (un-interruptible power supply). That way if the power blips for a little while it will retain it's settings.
