Thread: Spa blower noise
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    Spa blower noise
    My attached spa has a 2 hp air blower, which I was told did not work when we inspected the pool when we moved here. I got bored the other day and looked to see what was wrong with it. I opened up the pumphouse subpanel, and found one of the wires came out of the blower's breaker. Re-attached wire to breaker and fired the thing up, and it works, but it's LOUD! This thing sounds like a large shop vac, which wouldn't be a problem if it were inside the pumphouse, but the blower is mounted inside a fake rock about 4 feet from the spa Is it normal for these things to sound like that? I took the cover off, and the impeller is a little rusty, but not too bad and nothing else is visibly damaged. BTW, the blower supplies air to 6 in-floor nozzles in the spa, the jets get air from a venturi setup.
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
    Aug 2009
    North Central Texas
    1,358
    Re: Spa blower noise
    My last two free standing spas have and had pretty powerful blowers for the bubbles that come up from the foot and leg areas. The blower is the loudest motor of the four in the spa but not as loud as most of my household and shop vacs. The two jet pumps, at 5 HP each, are not nearly as loud as the blower. Of course these are all inside the enclosure but right under where one sits in the spa. The enclosure is pretty thin cedar planks with no insulation but the actual fiberglass spa has a lot of foam insulation on the underside side.
    When in the spa the noise of the bubbles helps to drown out the blower noise. The bubbles are loud enough to make having a quiet conversation difficult even sitting next to someone. The blower motor noise seems much louder when standing outside of the spa. It is not as loud as my shop vacs, all of them, and it is not nearly as noisy about 10 ft away from the spa. At that distance the sound of the rumbling bubbles is louder than the motor, even with the insulated cover on. (The spa goes through an automatic short cycle with all the motors once a day just to clear and refresh the lines and pipes.) The blower motor is the highest pitch also. This blower motor was a new replacement last year. It didn't give any indication it was going like water pump motors usually do, like bearing noise. One day it worked the next day it didn't.
    I can hardly hear the low flow circulation/filter pump even when I stick my head into the enclosure.
    I wonder if you could put some foam insulation on the inside of the rock allowing for free air movement and heat dissipation.
    BTW... my biggest, most powerful shop vac, 16 gallons, 6.25 HP is the quietest of all my household and shop vacuum cleaners and hand helds, except for the robot cleaners and the little Shark battery powdered vacuum (mostly brush action with low vacuum power but does a great job). The newest iRobot Roombas, the 5xx series, are pretty quiet, especially using the Aerovac bins, almost silent on soft surfaces (most of their noise comes from the locomotion and side brush motors), but the much more powerful "real" vacuum cleaning robots, Electrolux Trilobites, have pretty loud vacuum motors.
    I don't think I've mentioned lately how much I love my army/pack/gang of cleaning 'bots and gadgets.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    Good idea on the insulation! Think I might give it a try, I'll put it on the shopping list for the next trip to Home Depot
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by guamguy
    I'm going to let those more knowledgeable comment. There are, on the very basic level of common spray foams, two types. On has very high expansion and hard to control. The other has much lower expansion and is much easier to control. I think is is for use around windows and doors. I would practice on some cardboard before doing the final job. Also, it would be a good idea to put a temporary barrier about the motor while applying it. Once it sets it is almost impossible to remove from surfaces. Wear very old clothes and shoes too, and take off any watches and jewelery. Have recommended removing agent right on hand, by work space, and plenty of old rags and/or sturdy shop paper towels. Also, highly recommended is disposable vinyl exam gloves (or hobby gloves); lots of them. Once the foam gets on them, even a little bit, you have to take them off and discard them. Some foams and solvents/cleaners will actually dissolve the disposable gloves.
    gg=alice
