Thread: Temp sensor Heater issue
    I am getting a service light for temp sensor on a Jandy LX 400 heater. I have replaced the control board, temp wiring harness and both 135 and 150 sensors. What else can I check?
    15'x30' 18k gallon pebble sheen pool, 1.5HP Pentair WhisperFlo 2 speed pump, 420 sq-ft Cartridge Filter, Quik Pure 3 Ozone Oxidation System, Hayward Navigator, Gulf Stream HE125-T-A Heat Pump, (2) 3' waterfalls run by 1.5HP Pentair WhisperFlo 1 speed pump
    Re: Temp sensor Heater issue
    fixed - was a short in the wiring to the sensor grounding on the metal cover.
