Thread: Balanced pool causing itchiness? could it be...
    HardTrance9's Avatar
    Oct 2009
    Los Cabos
    184
    Hi all,
    One of the pools caused itchiness to one guest some days ago, but the strange thing is that the pool levels were ok..
    8,500 gallons
    bleach pool
    FC: 5
    pH: 7.5
    TA: 110
    CH: 250
    CYA: 70
    Do you read anything wrong here?
    I need to add one thing that I am not sure if it could be the source of this itchiness.... The pool has a problem with the drain and some other plumbing installation, so it was decided by the contractor taking care of this problem, to close the pool drain valve so it won't leak..(apart from other issues)..
    Do you think that this could be the source of the itchiness? I was just thinking something like "maybe if water doesn't circulate well... chlorine gets accumulated in the pool causing maybe the skin to itch?"... but I have no support on this thought.. is just an idea.. + the FC level is in range..
    What do you think?
    In charge of some SWG and Bleach pools... still a newbie..
    Aug 2010
    San Jose, CA
    12
    Re: Balanced pool causing itchiness? could it be...
    I'm fairly new to this myself, having owned/maintained a pool for only 6 months. But some thoughts are:
    - FC 5 is on the low end for CYA 70. See the CL / CYA chart: pool-school/chlorine_cya_chart_shock
    - Did the itchiness occur to only 1 guest as you stated? Maybe that person has sensitive skin. My son with mild eczema gets dry skin / rash if I use the wrong sunscreen or lotion on him.
    - With the drain shut off, I would wonder how well the water is circulating. Try testing water samples from different spots / depths.
    42,000 gallon, 24'x44' rectangle, inground plaster.
    Pool age 30+ years.
    Hayward C-4025 cartridge.
    Polaris 280.
    Feb 2008
    Denton, TX
    5,061
    I don't see much in those numbers that would cause one person's skin to itch when nobody else's did. I agree with dchan as far as not letting that FC go lower than that.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,002
    Quote Originally Posted by HardTrance9
    Hi all,
    8,500 gallons
    bleach pool
    FC: 5
    pH: 7.5
    TA: 110
    CH: 250
    CYA: 70
    What do you think?
    CC level is...? Those are the irritants, I'd check that.
    Oct 2009
    Los Cabos
    184
    Thanks guys. Seems like the person might be sensitive. There were two people, and only one felt the itchiness...
    I know skin on every person is different but oh well... Once a pool with 6 people was being used and only one guy got itchy.. pH was at 7.8 and once it was lowered to 7.5 he felt much better.. (he even had his own test kit, so don't know if it was more psychological or rational or so..but it worked to have it a 7.5 )....
    By the way CC was "0".
    Thanks!
