Thread: Hardi Backer for exterior applications
    This is a quote from Hardi backer faq on thier site. "In accordance with National Evaluation Service Report NER-405, HardieBacker board is recognized only as an interior substrate."
    Do not recommend Hardi Backer for exterior installs you are giving bad information.
    I hate to see people miss led. Professionals should know better.
    May 2009
    Topeka, KS
    81
    Re: Hardi Backer for exterior applications
    That is funny, Hardi backer makes siding that looks identical to the Board except it's about 1'x8' or so. I sold flooring at a national home improvement store. A guy bought a bunch of siding for his floor tile project, because it was much cheaper. I still wonder how his money saving project turned out.
    18x36 Buster Crab in ground, 3' shallow 8' deep, Hayward super pump, 300lb sand filter.
    Jan 2011
    Riverside, CA
    352
    You can buy 4x8 Sheets of the Siding Material. It comes with a 'stucco' finish and you can get it in a bunch of colors.
    Hardie isn't going to warranty your home built BBQ anyway.
    Someone should be able to find the exact makeup of the "Backerboard" and the "Siding" and I bet they are just about the same.
    40x20 Free Form IG Pool (aprox 29,000 Gal, 140 Perimeter, depth 3'6"-7', Baja Shelf, 8x8 Free Form Spa) - Gunite Shell, Pebble Plaster Finish, Poured Concrete Coping - 3 Deep Heat Returns - Jandy LXi400 Gas Heater (400,000 Btu) - Jandy Variable Speed Pump JEP 2.0 - Jandy CL 600 Filter - HASA Liquidator - Jandy PDA 6 w/ Remote - 4x Jandy WaterColors Pool LEDs - 48" Gas Fire Pit - 6x Gas Tiki Torches - 12'x15' U-shaped BBQ Island (Firemagic Equipment)
    http://www.troublefreepool.com/new-p...ca-t28413.html
