Thread: above ground winter cover
    Jun 2010
    Okeana Ohio
    12
    What is the best way to put on a winter cover and not blow off and not damage the pool? Should I use a air pillow under the cover? Any help is appreciated thanks
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,410
    Re: above ground winter cover
    What part of the country do you live in? Do you get a lot of ice and snow in the winter? So will just pump off excess water with a pool cover pump or brush the snow off before it gets too heavy instead of using the pillow.
    Some people use tie downs, like tent stakes or weighted old jugs tied through the eyelets along with the cinch wire to hold the cover on to an above ground pool.
    Love TFP? Become a
    TFP Supporter!
    Jun 2010
    Okeana Ohio
    12
    We live in Cincinnati Ohio and the weather can go either way bad or mild. The wind is what I am concerned with. I guess just as long as the cover does not blow off ?
    dremin2flyhi's Avatar
    Jun 2010
    Darlington, SC
    121
    If you have metal uprights --you can get metal d-rings and attach them to the uprights and use some extra bungee straps. I am in the south and have strong wind/ rain storms thru out the winter season.
    24' x52" Sharkline Venture (May 2016) ABG (13,500)
    Hayward S180T15932S --Sand filter/ Flo-Matrix pump pack
    Aquatrol-RJ SWG-- Nitelighter NLMC
    Dolphin E10
    Duraspa G2- Premium hot tub --Rotomold style
