Thread: How much water to drain
    Mar 2010
    Spring, TX
    1,082
    How much water do you have to drain, natural splashout, or evaporation before you see a change in levels such as CYA or CH or any other levesl that may be affected. I usually do not drain any as it is so hot here it will evaporate soon enough. My levels are fine, but about a month ago I tested and got a CYA around 40 and tested last night and got 30 doing it 2-3 times in a row. Also my CH dropped from 350-325. Nothing to worry about, but just wondering how much water loss you have before those change.
    Thanks.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: How much water to drain
    CH and CYA are not lowered by evaporation.
    As far as draining, you can assume even distribution throughout the pool so it is straight percentage. If you remove 20% of your water and refill with tap water you will have lowered CYA by 20%.
    With CH it is a little more complicated because the fill water has CH in it. A good estimate would be:
    • new ppm = ( % drained * ppm fill water ) + ( % remaining * ppm pool water)
    So if you have CH = 1000ppm and your fill water CH = 300 ppm and you drain 20%:
    • new ppm = ( 20% * 300 ) + ( 80% * 1000) = 860
    Obviously splash out is a very small percentage of the total pool volume, so it will have a small effect over the short term.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    A leak masked by an auto-fill can present as an unexpected loss of CYA or salt, change in CH, etc.
    Technically it is a proportion... like a percentage. Were your pool a CLOSED system (no sunlight, algaes, outgassing) if you'd remove 10 percent of your water, AND replace it with the same amount of distilled water and it should have 10 percent less of everything: TDS, Salt, Calcium, Alcalinity (correct me if wrong on that one), CYA... you name it.
    But it does leave a question behind: Why did the CYA drop 25% when calcium dropped only 8%? If you're using Cal-Hypo, that would answer it...
    (ninja'd)
    Pool: None, and All.
    ''What's really interesting is finding some way to explain some technical concepts with simple terms so that everyone might understand, to vulgarize.'' CaOCL2
