Thread: Intellitouch Questions
    Hi Everyone,
    I am from Australia, and im setting up an Intellitouch system with no retailer in Australia Im having trouble getting questions answered.
    1) I have a i9+3 Personality Kit, which is designed for a pool/spa combo. I do not have a spa and wanted to know if I can use
    the two valves that are located in valve positions 1 & 2, which normally use to change filtration and return water between the
    pool and the spa. Can I use these for something different??
    2) How does the solar heating control work? does someone have a design layout of how theres works? The solar systems in Australia seem to have a separate controller that monitors the temp of the water in the pipes on the roof and when there is a significant different in the temps between that and the pool water it activates a separate pump which cycles the water through the solar panels. This is done through separate solar inlets and returns, and also is designed to activate periodicity to keep the pipe water fresh. does the intellitouch do something like this??
    3) I notice in screen shots of the screen logic controllers eg Iphone it allows the control of landscape lights and to be able to dim them, is this done through the dimming module or something else? as I read it the instructions read that the dimming module only works on underwater lights??
    I would appreciate any help and thank you in advance.
    Shane
    South Central NJ
    3,192
    Re: Intellitouch Questions
    See this site for semi live Pentair help:
    http://innovationlab.pentairpool.com/
    Scott
    Owner of - PoolGuyNJ LLC
    Thanks Scott, i have posted my questions on there.
    If I cant get an answer ill phone them next week.
    Thanks Shane
    Rocklin, Ca
    467
    I might be worth it to use Skype for that phone call.
    11000 Gals, Intelliflo, Sta-Rite Cartridge, Polaris 360
    Pool I built in my old house: my-new-pool-build-t4534.html
