Thread: Algae and FC @19 PPM
    Jul 2009
    Charlotte NC
    31
    Heres the short of it. Water is clear with visible algae on bottom and sides (when brushed last nite,green cloud appears).
    I had algae a little over a week ago and dumped 4 lbs of 99 proof dichlor (strong stuff) into pool. I went away on vacation
    for the week and wanted this stuff gone. Tested FC in the morning before I left. 30PPM . Came home yesterday early evening
    with these results using TF-100 kit. FC 19PPM CYA about 90PPM. Ph appears to be 7.5 but who knows with FC so high
    TA is unknown. I used the kit as described. Mixed in chemical solution turns green, slowly add other chemical and solution
    turns yellow (high FC). Color is supposed to change to red to determine TA.After about 30 drops,which would have been
    a TA of 300, I gave up as solution was still yellow? Take care of algae first, then attempt PH and TA adjustments? Oh
    and the CC level was 1PPM but does that matter I can see the algae. Thanks
    16x34 kidney shape 19,000 gal vinyl IG
    Pentair IC-20 SWG
    Pentair sand filter
    Pentair 1HP pump
    22,548
    Re: Algae and FC @19 PPM
    First and foremost, you have not shocked the pool. With a CYA of 90 your shock level is 35ppm. You will have to reach, and maintain that level as often as hourly until you pass the OCLT (overnight chlorine loss test). Don't worry about your other levels until you're done shocking.
    Jul 2009
    Charlotte NC
    31
    I understand dichlor raises my CYA which I dont want. Im off to get some bleach. The pool calculator is a little
    confusing. If someone could confirm the amount of bleach I need to get my FC up to a shock level of 35 PPM,
    I would appreciate it. Thanks
    Pentair IC-20 SWG
    Pentair sand filter
    Pentair 1HP pump
    30,419
    It takes 11 gallons (not jugs) of 6% bleach to raise the FC to 35ppm in a 19k pool. Be sure to subtract your existing FC at the time you put the Clorox in the pool so your dosage will be less.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,993
    Quote Originally Posted by bluskyguy
    5 gallons of 6% will bring it up to 35 ppm, at the time you tested FC. Probably more, now.
    What's your Calcium level? You may have "room" to use Calcium Hypochlorite, which is a powder, and therefore easier to carry.
