Thread: Taylor K2006 and pH testing
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Hi I have a K2006 test kit I just bought and I just read the info below from Pool School. In the test kit directions for testing pH it does not mention adding the chlorine neutralizer before adding the pH test solution. should I be adding this neutralizer? my Fc tends to be around 5-7ppm.
    Thanks.
    "A measure of how acidic or basic (alkaline) a solution is. A pH of 7 is considered neutral, anything above 7 is basic and anything below is acidic. Pools are usually kept at a pH from 7.2 to 7.8. pH in pools is tested with the indicator phenol red. High sanitizer levels above about 5 ppm can interfere with this test and lead you to believe that your pH is very high when it is actually not! The better test kits will allow for this by adding a chlorine neutralizer to the indicator and calibrating their color comparator blocks to compensate for the added chlorine neutralizer so you can get accurate pH readings when your sanitizer levels are at 10-15 ppm."
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Taylor K2006 and pH testing
    Aquatica, the chlorine neutralizer is part of the R-0014 (0004?) indicator dye. You don't need to add it separately
    Some test kits include a separate chlorine neutralizer for use with the PH test, but the Taylor kits include it in with the PH indicator dye.
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Thats great. Thanks!
