Results 1 to 11 of 11
Thread: Trying to get the most out of my small yard
    Hi everyone! I've loved reading through this forum, I'm learning so much!
    I live in Oakland, California so space is an issue. I have a backyard that's enclosed by fences on our property lines. I think that we can fit a 15'x24' AGP back there but was wondering about a couple of factors:
    1) how much space do you suggest I leave between the pool wall/railing edge and the fences? I'm wondering what the minimum working space I might need to do things like replace the liner, when need be, or do some type of repair.
    2) How large is a 8 mil solar blanket rolled up on a reel? I would like to set the reel up at the narrow end of the pool up against the fence, but I need to know how wide the roll will be so that I can place the pool far enough away from the fence so that the rolled up blanket doesn't overlap with the pool at all.
    Thanks for all of your feedback in advance!
    Tammi
    18 x 36, 29K gal., ingound vinyl, Tagelus sand filter, Compu Pool SWG
    22,550
    Re: Trying to get the most out of my small yard
    Welcome to TFP.
    You'll need a minimum of 3' all the way around the pool and more where the entrance is.
    A solar cover is about 8 to 10" diameter rolled up. They're not very large at all.
    Jan 2010
    Central Valley, CA
    233
    And you need to check what the regulations are for your city. I didn't have to get a permit but did have to have 5' setbacks from the property line.
    Garden Leisure Voyager 12x24 AGP, 7500 Gallons, Hayward Power Flo Matrix 1 HP pump, dual speed, Hayward XStream Cartridge Filter, 120 GPM,
    Thanks for the quick responses!
    Hmmm...3' huh? I may have to go down to a 12'x24 then. Sportsman, that's the size of your pool, do you find it sufficiently large enough for let's say 3 kids playing and 3 adults lounging on floaties?
    With a 15'x24' I would be able to have 2.5' on either side of the 24' walls. Then I could have 4' on the 15' wall with the solar reel. And 10' on the other 15' wall where the entrance will be. Do you think this is doable Bama Rambler?
    Yeah, sportsman, I actually had to get a builder's permit because of the size of the pool. Anything over 5,000 gallons requires a permit. We don't have a setback rule for te pool itself, luckily just a 5' setback for the pump.
    22,550
    Those distances are workable. The sides are a little close but you work with what you have.
    One thing to keep in mind as well---your local codes may require a setback from any property lines/fences.
    ETA--Sorry didn't see the post above
    24' AG Doughboy w/ 5'8 dish bottom, CWII DE Filter, 1.5 hayward 2 speed pump, Aquatrol SWG.
    Jan 2010
    Central Valley, CA
    233
    Quote Originally Posted by lil'_fixer
    shows how different rules can be from city to city. I had zero setback rules on my pump so I can hide it behind my pool. I set my pool diagonally in the corner so I have landscaping behind it and it give me some working room.
    First, we'd always like bigger BUT 12x24 is enough for 2 adults 2 kids to play. I think 3 adults on floaties would be tight. We'll do two on tubes. Haven't tried full floaties because of extra size.
    Awesome! 15'x24' it is!
    Yeah, I was worried the a 12' wide pool would be a little narrow for adults to be on full size loungers, which is a must for my family. So I'm really glad you guys think the larger pool is doable in my yard! Now to level the hard clay dirt. I'll let you know how it goes
    Thanks for all of your feedback!
    another one's Avatar
    Jul 2010
    Seattle area, WA
    49
    Go get a couple of survey flagging tapes at the local hardware store. Put corner stakes for the pool and run tape between the stakes giving you an outline of the pool. Now mark the outline of your deck the same way with a different color tape. You can mark off the equipment pad as well.
    Now you can position furniture, walk around, look from the windows, and get a good idea how the pool with sit in your lot.
    29,000 gallon, 18' x 44' Indoor plaster pool - 8'x'8 spa in corner. Well water, TF-100,
    pool cover, Pentair MasterTemp 400k btu heater, Jandy RS-4, 4 x 105 sq ft cartridge filters,
    Wisperflow WFE-4 1.0 HP pump for pool, WFE-6 1.5 HP pump for spa jets, MagnaSweep.
    Jan 2010
    Central Valley, CA
    233
    Quote Originally Posted by another one
    I used stakes and a garden hose to mark mine including standing trying to imagine playing.
    I think I'll spend some time this weekend to try to really survey the area, stake it out, and visualize =)
    Thanks everyone!
