Page 1 of 3 123 LastLast
Results 1 to 20 of 52
Thread: Second Return and Fountain for Intex Pool
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    Hi Everyone
    I went ahead and made my first mod to my Intex pool. I created a second return and added a fountain. I used the idea from this post for the fountain http://www.troublefreepool.com/pool-...ol-t24483.html and this idea of using 1.5 PVC pipe added to the Intex pool fittings http://www.troublefreepool.com/intex...er-t25132.html. I combined both of the ideas into one contraption . The sand filter/pump has more than enough power to run the fountain and second return.
    * NOTE * All pipe and fittings are 1.5" PVC.
    * Construction *
    1. I took a four way fitting and added it to the Intex thru wall fitting.
    2. I then added an addapter to alow a .5" pool eyeball for the top return.
    3. I then added two ball valves to control the flow to the bottom return and the fountain.
    4. After the top ball valve I added a tee and two 12" pipes extending out each side with end caps.
    5. After the bottom ball valve I added a 26" pipe and 90' elbow with another .5" pool eyball.
    * Function *
    The contraption works by turning the ball valves. To control the fountain I just close the bottom valve to the bottom return to create more presure for the fountain. I then open the top ball valve to turn on the fountain. That is it.
    * NOTE *
    The top return is always flowing water even with the fountain on.
    Below are some pictures of the contraption mounted to the pool and running.
    Enjoy!!!
    Mark
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    Re: Second Return and Fountain for Intex Pool
    That's pretty cool. I love tinkering with things like that. I have a couple questions if you will indulge me. Did you carve out the threaded strainer connector/through the wall fitting to allow the 4-way fitting to fit? Is that eyeball a stock pvc item or was it a special order or pool store item? Thanks!
    18'x48" Intex metal frame pool, 1600 Intex sand filer/pump combo, Intex SWCG.
    Apr 2009
    Lakin Ks
    33
    Very cool fountain! What is the yellow thing on the side of the pool? If it is a light is it wireless?Very good idea of the edging along the edge of the sand!
    5,000 gal above ground pool summer escapes pool
    crookm11's Avatar
    Jun 2010
    422
    Quote Originally Posted by gayler
    The yellow thing on the side of the pool is the Intex magnetic light. the light is not wireless.
    Mark Crook
    Apr 2009
    Lakin Ks
    33
    Do you have much trouble with the salt water chlorinator? I've had to replace mine twice.
    crookm11's Avatar
    Jun 2010
    422
    Once I got my water chemistry correct I have had no trouble with it. If you are having troubles try reading this article in pool school. If you have the intex SWG you can't change the percentage setting on it like the article talks about.
    Mark Crook
    Jul 2010
    Bixby oklahoma
    80
    thats pretty cool. When I made the one for the intake I was struggling with how to do a fountain. The angle of the soft side pools is testing my creativity. Right now my pool is green as grass, LOl..
    Im planning on draining it and do some work to the ground to smooth it out a bit. This is going to make me want to make a fountain for sure now while Im working on it.
    good job!
    20'x 48" Intex.
    crookm11's Avatar
    Jun 2010
    422
    Quote Originally Posted by foster400
    good job!
    Thanks for the reply.
    I have taken down this pool and will be putting up a bigger Intex this year. I will be using the same setup for the new pool. Checkout this thread. It is showing my renovation of the backyard.
    Mark Crook
    May 2011
    Richardson, Texas
    29
    I think they may have changed the return fittings since this was done. Mine looks nothing like that. How do you get it to fit the return fitting?
    Intex Ultra-Frame 18x52
    Intex Sand/Salt Filter
    crookm11's Avatar
    Jun 2010
    422
    Quote Originally Posted by Texan78
    The return fittings are still the same. What questions do you have about the fittings? The fittings you see have been modified but started out ar the standard Intex fittings.
    Mark Crook
    Sep 2009
    Greentown, IN
    914
    Looks nice and you're pool water is sparkly too!
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    May 2011
    Richardson, Texas
    29
    I noticed your fitting is threaded at the base on the inside similar to the skimmer side. Mine isn't threaded. When I get home tonight I will take a pic and post it so you can see and get a better understanding. I love the idea and would like to add a fountain but not seeing how with the return fitting I have.
    May 2011
    Richardson, Texas
    29
    I got home late after dinner after the sun had already gone down. So this isn't really a good pic but you can get a idea. I will take a better one tomorrow. As you can see it is different then yours. If this is the same one, what exactly did you do to make the PVC fit it?
    May 2011
    Richardson, Texas
    29
    Here is a better pic during the day. As you can see it doesn't have a threaded base. What did you do to make it fit?
    crookm11's Avatar
    Jun 2010
    422
    You have the same fitting as do. You have to unscrew the return cover off of the fitting. Not just the the little return ball but the whole cover. Once you take the cover off you will have to pry off another screen then you can add the 4 way PVC fitting to the Intex fitting.
    Mark Crook
    May 2011
    Richardson, Texas
    29
    Ah ok that makes more sense now. I had a feeling that might have been the case but wasn't sure. I tried to unscrew it a couple times but it is on there good so then thought maybe it doesn't unscrew. When you unscrew that top piece will it come free from the liner or is that just a piece that is screwed onto the fitting?
    -Thanks
    Jul 2010
    Bixby oklahoma
    80
    its just a piece of the thru wall fitting. They can be hard to unscrew.
    I was able to make a fountain for my easy set pool and the kids love it.
    20'x 48" Intex.
    Jun 2011
    Memphis, TN
    12
    HI
    I was so happy to see that someone finally figured out how to make a fountain for the intex pools!!!! HUGE THANKS
    I ran across your post the other day and had to make me one, so that day I went to my local hardware store and bought all the items you listed and I took along the pictures you posted so they could see what I was wanting to do. I had to make a few adjustments because I don't have a big pump like you do. I kept the 2" 4 way then I reduced everything else down to a 1 1/2", on the bottom return I had to hook in a 2" adapter so the pool eye would fit correctly.. They only come in a 2" size so I didn't have much other choice. I now wish I would have went down to a 1" cause the pressure is a lil lower than I would like. Nothing that I can't deal with.
    18'x48" Intex metal round frame
    Intex 2000 GPH SWG
    [center:1sev5ihv]~Professional Pool Floater~
    18'x48" Intex Metal Frame-Blue
    2500 Intex Krystal Clear SWCG+Pump
    Fountain w/2nd return[/center:1sev5ihv]
    crookm11's Avatar
    Jun 2010
    422
    Quote Originally Posted by stacey81881
    HI
    Intex 2000 GPH SWG
    Thanks for the comments. I'm glad you were able to follow my pics and description.
    Start a different topic with some pictures of you modification and I will add the topic to this thread Useful Links for Intex Pool Owners.
    Mark Crook
  20. Back To Top    #20
    I was trying to figure out myself how to remove the outer screen on the adjustable nozzle/inlet...the fountain I bought has a 1 1/2 inch threaded end, so even if I am able to get the screen off the opening looks way to big for the fountain I have. I hope this makes since and really hope someone can offer some advice
