Thread: Will my shop vac blow out my lines for closing?
    flyboy320's Avatar
    Jul 2009
    Burlington, Ontario, Canada
    216
    I have a 10,000 gal IG that I want to close this fall myself. It doesn't have a main drain, but does have a water fall that is about 3' above the water line that will need to be blown out. I have a Ridgid 4hp shop vac and I'm wondering if this will be enough?
    I have also seen some links to a Balboa Mighty Vac and also a Cyclone 3HP blower. I don't know much about blowers, but it would seem on the surface that my 4HP shop vac is more powerful that the other two....
    10K gal IG, vinyl, 1 HP Jandy Stealth pump, Jandy CS cartridge filter, Delta UV system, Hasa Liquidator
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Will my shop vac blow out my lines for closing?
    I use that cyclone vac myself. I can't say if it's stronger than your shopvac, but it does it's job well. If using a shopvac I always recommend using some pool antifreeze
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Johnl's Avatar
    May 2008
    Montgomery County, PA
    88
    Since you don't have a main drain, your probably fine with the shop vac.
    23K Gunite IG Pool
    Waterway Crystal Water SVL56 Pump/1.5HP AO Smith Motor
    Hayward Star-Clear Plus Cartridge Filter C17502
    Aquarite 40k SWG
    Polaris 360
    flyboy320's Avatar
    Jul 2009
    216
    Ok, thanks guy's. I'm going to try a "dry run" next week when I get a few days off and try and see if my shop vac will blow the waterfall out before I actually have to close for the winter, that way I still have time to get something if the shop vac doesn't work.
    Cheers.....
