Thread: Rubber boots for odd sized pipes
    Aug 2010
    UK
    27
    Whilst working out how to fit my 1.5 inch standard flexible pipe to my intex odd sizing I came across this site. They do boots that simply clamp at either end. Hope this is of use to others. I plan to connect my pipes to the intex in and out plungers in the side of my intex pool. Comments?
    http://www.koilogic.co.uk/store/go/category/5/219
    Intex Ultra Rectangular AGP 18*9*4
    Certikin hydroswim HPS .5hp pump
    Azur 15" Sand Filter (pentair)
    EGFM glass particles (10kg of 1-3mm and 25kg of .5 - 1mm)
    Calorex AW910 Heat Pump
    Re: Rubber boots for odd sized pipes
    The only things that I would be hesitant about are:
    1) the metal Hose clamps. they can creat nice gouges in peopl and possibly the pool itself
    2) is there enough of a nipple on the pool for the pipe to mount.
    17,000 gal, Posi-Flo Sta-Rite cartridge filter, IG, pebble, Water Ace (GE) 1 HP/1.25 SF 115/230V, 100 GPM (Resid.)/37.5 GPM (public pool), 102 SQ FT filter. Future upgrade: 250 SqFt filter.
    Guest
    My thought is that now would be a great time to redo as much as you can with rigid PVC, and you'll never have to worry about stuff like this again! By the way, I'm not a fan of flex pipe!
