Thread: Spillover Spa question
    Hey guys, I am brand new so please forgive my ignorance. I have a Prestiege spillover lounge spa. In the bottom of the spa there are about eight gray circles (silver dollar size) and when the blower is on bubbles will come up from them...well four of them. The four on the other side will only work for about 2 minutes. There are two levers on the spa itself, when I turn one of them the four that work turn off. When I turn the other lever I get nothing at all.
    When the spa is off I can feel water coming out of all eight circles. Any suggestions? I checked the swiths and cleaned them.
    Re: Spillover Spa question
    Does this happen when air gets in the lines?
    Nevermind, I got it figured out. Thanks for all the helpful tips and suggestions.
    Mar 2007
    San Rafael, CA USA
    12,082
    So to help others, please share what you found out. Was it that the circulation pump is on all the time even when you aren't running the jets? So four are used for pump circulation while four are for aeration? Did you figure out why the four probably used for circulation only have aeration for a couple of minutes?
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    18x38 Inground Liner (25k gal) Paver surround, multi-speed pump, DE Filter, Raised spill over spa, TF-100
