Results 1 to 10 of 10
Thread: hairline cracks in concrete
    Curious if and what I need to do with some hairline cracks on my pool deck concrete. I live in southern CA so freeze issues are almost non existent but do I need to do anything to prevent them from getting bigger.
    18,900 Stonescapes Tahoe Blue xtra black, 8 jet Spa, Pentair inteliflo VS , Pentair FNS 60 DE, Inteliclor40, Pentair 400,000 Mastertemp heater, 3 spillovers powered by a Pentair 1 HP whisperflo pump, The pool Cleaner, 2 Intellibright color changing lights and 400 sq ft. of Heliocol roof mounted solar.
    South Central NJ
    3,192
    Re: hairline cracks in concrete
    There are many reasons concrete can crack.
    Eventually, nearly all concrete will crack. We really don't have enough information. It could be from the environment, earth movements, poor prep, poor cure, poor mix lack of expansion joints, or a combination.
    Scott
    Owner of - PoolGuyNJ LLC
    Thanks!
    Do I need to worry or is there something I can do to keep it from expanding.
    South Central NJ
    3,192
    Concrete expands and contracts with temperature. Expansion joints, either plastic, felt, or saw cut are used by masons as stops to halt a crack's progress.
    Reducing the frequency is what the mason is paid for. His skills in recognizing what each pour needs in prep, materials used and how much of what additives are what command the $$s.
    Scott
    Thanks! My question is now that I have a couple hair line cracks is there anything I can do to prevent the cracks from growing, etc.?
    South Central NJ
    3,192
    Without seeing the environment or soil conditions, I can't tell.
    Scott
    What specifically do you need to make an evaluation?
    Cherie's Avatar
    Jul 2008
    Wylie, Texas
    506
    Not for nothing, but I would suggest that you keep the area around the pool adequately watered, from a stay-at-home-mom, just sayin'.
    32x16 buried Doughboy, 4' shallow - 7' deep
    Pentair Dynamo 1 hp, 2-speed - Pentair 150# SD40 w/zeolite (75#)
    One skimmer/two returns/Aquabot Turbo T2
    South Central NJ
    3,192
    Drainage, soil conditions, construction, and age are the primary things I look at.
    Scott
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    All concrete cracks eventually. Doesn't mean it's going to break apart - there's steel mesh and/or rebar inside. Usually it's caused by ground settling. There are crack fillers sold at Lowes and the like. Frankly, they look like hit. The color stands out, and of course the stuff's too thick to flow deep in the crack where you could smooth it out. It ends up looking like the street after the city puts tar on the cracks in it.
    Hairline cracks, I'd leave alone. If your expansion joints are crumbling, do something about that, because that's where water gets beneath the concrete. Sometimes it's redwood bender board that has rotted over the years, sometimes it's that plastic **** that gets brittle with sunlight and breaks up. There are some nice caulk-like products that you can use to seal those areas up.
