Thread: pH testing
    Mar 2010
    Spring, TX
    1,082
    pH testing
    I was looking in my kit and I am running low on the pH drop test reagant. I have seen the same test kits at walmart. Will this test kit work the same as what is in the TF100 kit. The only reason I ask is that is all I need as my other ones I just ordered recently.
    Thanks.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: pH testing
    The ingredient is the same (phenol red), but the concentrations are different depending on the size of the sample to be used. You'd have to replace it with the same number Taylor reagent (R-0004, I think).
