Thread: Easy Touch Repair Question
    coog61's Avatar
    Nov 2009
    Richmond, TX
    84
    I need to replace the water temp. sensor on my Pentair Easy Touch. Since I assume I will need to turn off the circuit breaker, will this erase all the settings? Just don't like to be surprised.
    Thanks.
    17,500 Gallon, SWG 33' x 21' freeform w/ Sunstone Cobalt Plaster. Attached 6 X 6 Spa raised 12" w/ 6 Jets with Moss Rock Spillover. 25' Moss Rock Waterfall. Pentair Intelliflo VS-3050 for Pool, 2 HP Whisperflo for Waterfall, Pentair Clean & Clear Cartridge 320, Pentair 400K BTU Max-E-Therm heater, Pentair Intellichor, Pentair EasyTouch 4P, Pentair Legend Platinum Cleaner w/ 3/4 hp pump, autofill system, nat gas fire pit. BBB convert
    http://www.troublefreepool.com/new-tx-pool-t17907.html
    Dec 2009
    Central Massachusetts
    2,690
    Re: Easy Touch Repair Question
    No. Turning off the breaker for the Easytouch retains the settings. They are stored in the Eproms.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    coog61's Avatar
    Nov 2009
    Richmond, TX
    84
    Thanks. I actually found this out for myself yesterday. A storm rolled through and we lost power for 7 hrs. After the power came back all the settings were still there. Yea!
