Results 1 to 7 of 7
Thread: Options for slippery steps?
    Aug 2010
    Nyack, NY
    35
    What options are available for slippery steps?....A friend of mine has his vinyl liner installed over his steel steps to create a more uniform look, but the flip side is that his steps are very slippery.
    I am considering either a vinyl or fiberglass pool next year, and was wondering what options there are to give better grip for pool steps. Im so used to the sandy grip feel of a gunite pool I owned in my previous home..Im hoping there's some sort of options available.
    ~When I was a child I caught a fleeting glimpse out of the corner of my eye.....~
    -Name the song and group!-
    22,549
    Re: Options for slippery steps?
    Either vinyl or fiberglass should not be slippery. Slippery means something is growing on it even if you can't see it. A good regular brushing and keeping the FC at the proper level for your CYA will prevent it from being slippery.
    My vinyl liner is squeaky when you rub your hand or feet over it.
    Dec 2009
    Central Massachusetts
    2,690
    I have vinyl over steel steps too. Never had slippery problem either. A lot of times, the water circulation is not as good as it should be near/over the steps. Like Bama said, check you FC and make sure it's at the proper level.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    All liner manufacturers have a "Textured" option for vinyl covered steps. Sometimes it's standard, sometimes you have to specify. I'm not entirely convinced that it prevents slips, but I'm sure it helps a little.
    When they build your pool, ask them to install "Rotating Eyeballs" at the steps for increased circulation. That should help keep the algae at bay.
    Good Luck
    Making Liners Since 1997
    Pool Liner Factory Outlet
    Dec 2009
    2,690
    Quote Originally Posted by LinerMfgr
    Good point. I forgot to say mine is textured a bit.
    Aug 2010
    Nyack, NY
    35
    So if I understand this correctly, If you have steel steps, they have a different liner over it then the pool liner??....or do you mean, if you are getting steel steps in your pool, you should choose an entire pool vinyl liner that has a textured option?
    Dec 2009
    2,690
    No, your not understanding correctly; the liner is still one piece. The part of the liner that goes over the steps has a bit of texture on it. The rest of the liner is smooth. In fact, the part of the liner that goes over my steps is solid blue, while the rest of the liner has pattern on it. We could have gotten the steps with the same pattern on it. We just chose to have the steps all blue. Better contrast that way.
