I have a 120 volt acid pump that I need to hook up and want it to run with the pool pump. The problem is the timer is a 240 volt timer (see diagram). Can I hook up the black wire to lug 2 or 4 on the timer and the white wire to the neutral bar to get the 120 volts I need and still run with the timer?
[attachment=0:1vay6se3]untitled.bmp[/attachment:1vay6se3]
