Thread: Weird pump action
    Weird pump action
    Long story short. In ground pool with Hayward Super Pump and S-200 filter.
    I was vacuuming the pool to waste and suddenly I heard a whoosh-regular flow from the discharge. I went to the pump and saw the basket/pump water volume go to about ¾ full to ½ full (the whoosh) then back to ¾. It did not fill the basket.
    Since I was vacuuming, I though that perhaps something may have been vacuumed into the impeller of the pump. I took the motor off and cleaned the impeller. (There was nothing significant there.)
    When I restarted the same ¾ to ½ full action was repeated.
    When this is happening, there is flow through the system all be it at a minimal force.
    What is going on?
    Galveston, Texas
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Weird pump action
    Kinda sounds like an obstruction in the line. Did you use a vacuum disc or did you put the vacuum hose right into the hole of the skimmer?
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
