Thread: So confused with my test results!
    Hi all
    I have the Taylor k-2006 test kit. My test results are as follows
    Ph 7.5
    Fc 6
    Cc 0
    Ta 120
    Ch 280
    Cya 120 (has been 100-120 all season)
    I was concerned with the high cya considering I have not added any stabilizer this year. I when to the pool store and their numbers are as follows
    Ph 7.7
    Fc 5.5
    Tc 5.5
    Cc 0
    Ta 106
    Ch 180
    Cya 15
    My test strips agree with the pool stores numbers. My question why the big difference with the cya and ch? Please help!
    Pool is 25,000 vinyl w salt. Thanks
    25,000 vinyl w Hayward Aqua rite salt located north nj. Waterfall, spillover spa, Polaris 280, I-Aqualink 2.0, Solar fully automated,
    30,419
    Re: So confused with my test results!
    Welcome to the forum.
    Throw away the strips and the pool store tests. YOu will find post after post after post on thios forum where pool store testing and strip testing is simply inadequate.
    You have a very good kit.....use it and trust it.
    YOu didn't ask but you need to get rid of some of that CYA. Carrying that much in your pool will bite you sooner or later.
    Thanks for your quick reply. Do you think it unusal that my cya has been high all season and I haven't added any stabilizer? This is the main reason I think I'm using my test kit incorrectly.
    Thanks
    30,419
    I'm not sure I understand your question.
    CYA can be added as a seperate item (usually in 4 lb containers) or it can be added by using stabilized chlorine.......that normally means using pucks.
    There is really no other way it can get in your pool.
    Butterfly's Avatar
    South Carolina
    10,045
    Here's a link to Taylor that has pics that have helped many of us read the CYA test: http://www.taylortechnologies.com/Chemi ... ntentID=44
    You're done SLAMing when:
