Results 1 to 15 of 15
Thread: motor repair advise needed Hayward powerflo sp1580Z2 1.5hp
    Aug 2010
    Conn.
    3
    Hello all. Need some help fixing a motor. I have a Hayward power flo lx sp1580z2 1.5hp pool filter motor. Breaker popped and the motor now only hums when turned on. Did a few searches to see if I could fix it. The shaft spins freely so I thought it was the capacitor. After taking it apart I see no capacitor. The ones I saw online were silver cans. There is a small connection board with contacts that looks fine. The only other thing in there is a Klixon CGJ133 small round plastic case with 3 wire connects and 2 wires going to it. From searching online I’m guessing it’s a thermostat that is not available anymore. Replaced with a M2 series. Again that’s from a little googling.
    Is there a capacitor or anything else in that motor that could be bad or do you think it's the Klixon thermostat I should try changing?
    Thank you
    Jay
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: motor repair advise needed Hayward powerflo sp1580Z2 1.5hp
    It should be a capacitor start motor. They will put the capacitor either in a hump on the side of motor or in back end. Here is a picture of both versions. However, the matrix should be in the back end of the motor. Can you take a picture of the back end without the cover?
    Mark
    Aug 2007
    near the swamp
    806
    there's no capacitor on this motor, at least on the dozens I work on everyday. The replacement motors yes, but not on the original.
    Aug 2010
    Conn.
    3
    Quote Originally Posted by DBfan187
    That's what I am seeing.
    Is the Klixon component what I need to change?
    Just wrote this prior to seeing last post.
    Thanks for the fast reply Mark.
    My version of the SP1580 motor is on the right in that picture. Very hard to find a picture of the actual pump and motor I have. I believe it’s the “Z2” on the end that makes mine a little diff. It’s not even listed in the manual from Hayward. Data plate on the unit “SP1580Z2”.
    There was nothing under the black plastic rear cover. I removed the 4 long screws and tapped the back plate off. Attached to the plate is the board with contacts that all the wires go to and the small round Klixon component 2 wires go to. There is nothing else inside as far as electrical components. The other side does not look like it comes off. There’s a black plastic fan on the side the impeller is on.
    Thanks again for the help Mark.
    Jay
    mas985's Avatar
    Pleasanton, CA
    11,737
    The label SP1580Z2 is for the pump itself not the motor. The motor should have a number like SPX1515Z2E.
    Given both your comments the motor must be a simple split phase start. It should have a centrifugal switch in the back end and if that broke or the contacts are corroded, it could prevent the motor from starting. If not the switch and the shaft turns, then it is probably a winding problem which will require a new motor.
    Mark
    Aug 2010
    Conn.
    3
    Thanks everyone. After reading this I decided to go clean the contacts. Fired right up.
    Anything I should do before re installing this unit? I'm going to clean and lube.
    Thanks
    Hi there.
    I'm not very good with electrical. Does anyone have a picture that might explain what I need to do to clean the contacts? My motor didn"t restart after I shut it down to do a backwash. It just humms without pumping. I checked the impeller and it is rotating fine,
    Any help is greatly appreciated.
    Thanks
    Tom
    mas985's Avatar
    Pleasanton, CA
    11,737
    Posting a pump model# and/or motor# would help identify the type of motor you have. It might not have any contacts but it could have a capacitor.
    Mark
    Quote Originally Posted by mas985
    But of course. I should have know better. Here it is Mark.
    I have a Hayward Super II Pump
    Motor Model # C48L2N13B4
    It is a 1 HP Motor
    Thanks in advance.
    Aug 2007
    near the swamp
    806
    ST1102, that does have a capacitor
    Thanks, but what does that mean? Is there anything I can do to get it working again?
    It had hummed before but did kick in eventually. I tried the 2x4 method yesterday but no luck.
    Please let me know.
    mas985's Avatar
    Pleasanton, CA
    11,737
    It could be either the start capacitor, contacts or even a bad bearing. Does it make a lot of noise when it does run?
    The contacts are probably the easiest to check. To clean the contacts, you have to remove the back end of the motor (after turning off power of course).
    Mark
    It doesn't make much noise and the impeller turns okay. I'll take it apart but I don't know what I'll see. Where are the contacts?
    mas985's Avatar
    Pleasanton, CA
    11,737
    They are at the end of the motor on top of the shaft, you can't miss them.
    Mark
    Looks like I'll have to ull the motor out completely. The back of the motor is 4" from the wall of the house and I cannot get my head in there to see.
