Thread: Zero CYA???
    Apr 2010
    Southern California
    83
    Zero CYA???
    Went to a nearby pool store for the first time to get a full set of numbers. My kit does not test for CYA, but I added it based on the directions on the CYA bottle and I added 4 pounds, which was the full bottle. Since then I have probably only replaced around 6" of water in the pool. Anyway, the guy at the store said I have ZERO CYA, which does not seem possible to me, based on the fact that water replacement is the only way to lose CYA, and I have not replaced very much.
    So is it even possible that I could really have no CYA at all?
    12,000 gallon IG (newly re-plastered) pool, Pentair 3/4hp pump, DE filter, TF-100 test kit
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Zero CYA???
    It's very unlikely. There is a way for the CYA to go away, but only if your Free Chlorine (FC) level went to zero and bacteria converted the CYA into ammonia (and intermediate chemicals on the way from CYA to ammonia). If that happened, you'd have a very high chlorine demand and a zero FC reading.
    The most important advice given on this forum is to get yourself a good test kit such as the TF-100 or the Taylor K-2006. Without a good test kit you are simply shooting in the dark. A proper test kit will pay for itself many times over in chemical savings and in the time saved from not having to fix problems with the pool. Pool stores are notorious for giving incorrect test results, especially for the CYA test, and using test strips often gives the wrong CYA reading as well. Please, please get yourself a proper test kit.
    solarboy's Avatar
    Aug 2010
    Europe
    337
    Re: Zero CYA???
    I second that. Sadly I only have test strips. I've added enough Trichlor without backwashing to have 40ppm CYA yet the strips show nada.
    Self built 5500 gallon bare concrete (temporarily) pool with limestone coping, Pentair Swimmey 1/2 HP pump, Triton sand filter with DE, Simpool peristaltic muriatic acid pump with pH sensor and Monarch SWG. Home made solar heater with Pentair Compool control panel and 3 way valve. 1 skimmer, 1 main drain, 2 returns, 2" plumbing, Hayward auto fill valve.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Zero CYA???
    See if you can get the Palintest SP 315C kit as well as the Palintest SP 300 though the latter may only be available in the U.S. Palintest is generally available in Europe so hopefully available in Portugal.
    solarboy's Avatar
    Aug 2010
    Europe
    337
    Re: Zero CYA???
    Thanks for that Richard, top of my shopping list.
