Results 1 to 8 of 8
Thread: Can I have algae growth without CC?
    Near Nashville TN
    50
    I have noticed, what I thought was dirt, some slippery light brown slimy stuff, that brushes easily-some sort of algae- It's a pretty new pool but here are my numbers-
    Salt water Pool, vinyl, 27,000 gallons
    80 degrees
    1.5 TC , 0 CC - Has been holding strong at around 3.5 in our hot 95 degrees days- getting a lot of rain lately though. I turn my Autopilot off from 10 pm till 8 am. From there its on high spd till 6p, then low speed til 10. Maybe I should run pump 24/7??
    180 TA- (I know, working on it)
    7.8 PH- Just added acid
    CYA- 40 (working on getting it to 70)
    I didn't think algae would grow with 0 CC, but obviously it can- verified with TFT-100 test kit FAS-DPD
    I just threw in 3 jugs of bleach, and 3 qts of acid, and 6 pounds of CYA
    20x40 In ground Grecian Lazy L- Vinyl
    AutoPilot SWG Dig-220, SC-48
    Hayward Dual speed 1.5 hp pump
    Hayward sand filter
    Blue Diamond Robotic Vacuum
    BBB method BABY!!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Can I have algae growth without CC?
    Yes you can have algae without CC. Usually with low FC like you had.
    Feb 2008
    Denton, TX
    5,061
    The presence of CC is just an indicator that chlorine has combined with organic contaminants. One can have a green pool in any degree, with or without CC.
    Aug 2010
    San Jose, CA
    12
    Quote Originally Posted by JohnT
    I have a similar situation.
    FC 6
    CC 0
    CYA 50
    PH 7.2
    Water has turned slightly green the past few days, with some green deposits on my steps. Overnight FC test shows no noticeable drop, and CC remains between 0 to 0.5. Test results were taken with a TF100 kit I bought last week. To be safe, I've started the shock process, but curious as to why no CC and no measurable overnight FC loss.
    42,000 gallon, 24'x44' rectangle, inground plaster.
    Pool age 30+ years.
    Hayward C-4025 cartridge.
    Polaris 280.
    Mar 2007
    San Rafael, CA USA
    12,082
    Are you sure it's algae and not pollen (or metals, though you said you saw deposits on the steps and your pH isn't high)? Pollen as well as dirt can sometimes not show CC nor overnight loss. It depends on the quantity and type of pollen since some doesn't react with chlorine very quickly. Take some of what you have on the steps and put it in a jar of pool water and have it outside in the sun -- cover it with cheesecloth if you've got a lot of pollen in the air. If it's algae, it should continue to grow in the jar (especially if you put a tiny amount of fertilizer in it) though at some point when the chlorine drops you could get real algae growth but that might look different than what you are seeing. If you have a microscope, you can look at the substance that is on your steps -- algae is semi-transparent and often oblong in shape while pollen is usually round and solid in appearance and sometimes has spikes.
    Aug 2010
    San Jose, CA
    12
    Pollen and dirt sounds like a good possibility. It has been really windy the past 3 days so a lot of leaves and debris have fallen in the pool, especially bay leaves with a sticky residue. I've skimmed and brushed every evening, but I'm sure plenty of junk is getting into the water. I dont have a microscope, but will try the jar test if more deposits appear on the steps.
    Tested the water again this evening and still no significant FC loss or CC levels. But the water has become a darker green. I've boosted FC to 20 with Clorox bleach.
    Pool age 30+ years.
    Polaris 280.
    Aug 2010
    San Jose, CA
    12
    Oh, and even though the recommendation here is that phosphates dont matter, I went ahead and added Phos Free since I had it sitting on the shelf. Bought it and a bunch of other stuff before I went to Pool School.
    Pool age 30+ years.
    Polaris 280.
    Mar 2007
    San Rafael, CA USA
    12,082
    If you do have phosphates in the water, then the phosphate remover may make the water quite cloudy. PhosFree might have a clarifier in it to help clear such cloudiness; otherwise if you get cloudiness that doesn't clear up you may need a clarifier as well -- one of the downsides of using a phosphate remover.
