Thread: New Pool Test Results Need Help
    firemanast's Avatar
    Aug 2010
    Bentonville, Ar
    2
    Test where done with a TF100
    FC 1.5
    TC 1.5
    TA 100
    CH 50
    CYA -20
    I have put 18 pounds endura and one gallon of muratic acid 2 pounds shock and 2-3 inch chlorine tabs per pool store. I would like to go with BBB method.
    What do you suggest now ?
    Thanks
    24'x52" AGP (13,500 Gallons)
    Aqua-View 20" High Rate Sand Filter
    1.5 HP Powerline Pump
    30,421
    Re: New Pool Test Results Need Help
    I would like to go with BBB method. What do you suggest now ?
    Welcome to the forum.
    This may sound just a little harsh but it's not meant that way....If you are interested in BBB then you must start taking charge of your pool. Have you read the ABC's of Pool Water Chemistry in Pool School? Does it make sense? The sooner you get involved in learning what your test results mean and how to adjust them the soonwer you will become a BBB'r.
    Questions and thoughts.....
    1. What is Endura?
    2. Shock is a process you do to your pool. It is not a product although the pool stores will have you believe that it is. What was the ingredients listed on the package?
    3. delete
    4. What is your pH after the addition of the muriatic.
    5. Skip the chlorinating tabs for now....unless you have purchased a whole bucket...let us know.
    6. Our advice will often conflict with the pool store. You will not be able to cherry pick but will have to use the advice here (and become a BBB'r) or use the advice of the pool store.
    7. Tell us how your water looks.
    8. take a look at other posters sigs and enter the pertinent info for your pool in your sig. That'll help
    Again, don't take it as harsh but rather some direct advice to get you started quickly and effectively. YOu will need to do a lot of reading in Pool School and ask a lot of questions.
    firemanast's Avatar
    Aug 2010
    Bentonville, Ar
    2
    Endure - Sodium Tetraborate Pentahydrate
    Shock - Calcium Hypochlorite
    PH 7.8
    Water is clear
    And yes I have read Pool School.
    I what to go with BBB Method and get away from pool store.
    I know I need to add bleach and stabilizer but how much.
    Also what else would you like in my sig about my pool ?
    30,421
    Click on the "pool calculator" link in my sig and use it to help you figure the dosage for stabilizer and bleach
