Results 1 to 8 of 8
Thread: Best SWG
    Best SWG
    I am new and want to install a SWg, 25,000 gal. in ground. What would be the best, most economical and best place to purchase. I know this is a personal preference for people. I am just trying to learn what to stay away from. I know all re-sellers will say theirs is the best.
    Thanks
    Taz
    Playas Del Coco, Costa Rica
    36'X16' in-ground. 25000 gallon
    3/4/HP Hayward with 280 pound sand filter
    AquaRite SWG
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    Re: Best SWG
    I own the Intelliclor IC40 and like it
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    Jul 2007
    Brisbane, Australia
    874
    Re: Best SWG
    it's hard to say what's the best because to know you need to have owned quite a few
    Re: Best SWG
    There are also many different criteria by which they can be judged. The Intex wins on price, but loses in every other way. The AutoPilot units win on features, but are very expensive. It all depends on what is important to you.
    Re: Best SWG
    I've been using a CircuPool for about a month now, and am happy with it. The unit runs at 60% for 9 hours a day to keep up with my pools daily FC loss of about 3ppm. It did need to be calibrated when first installed, as the salt level was not being reported properly, but no problems since. The price is hard to beat.
    17,000 Gallon plaster pool. Hayward Perflex EC65 DE Filter. 3/4 HP Hayward Superpump converted to dual speed. CircuPool RJ45. Skimmer, floor drain, two returns.
    Re: Best SWG
    When I was designing my pool in France my engineering challenge was for a pool to be autonomous for up to 9 months at a time. A salt water system was an obvious choice and I chose an over-sized Autopilot SC-60. I really am a manufacturer's worst nightmare as I put this thing in 7 years ago and have not touched it since. I have not checked the electrodes and I only cleaned the gauze filter this month to see how low I could get my new Intelliflo pump and still operate the Autopilot flow switch. I did not reduce the power to give me 50%, but just set it at 9% and leave it. this keeps the Cl level at around 5ppm when I am away and I dial it up to 16 when we are in France and swimming and keep the Cl a bit lower. Thus for me it has not been that expensive and has been worry free. I have never had to add acid as my pH stays under 7.8. I have never had any algae in my pool and I can turn up on any day of the year and have gin clear water.
    I am thinking about buying a brand new unit as a standby in case it dies on me one of these days. I would do the same in a heartbeat.
    Ian
    27,000 gal liner pool. Hayward S360SX 36" sand filter, Dolphin Dynamic robot cleaner, Dolphin Supreme M4 pool cleaner, Aquatemp FT40Kst 3 phase Heatpump, Pentair IntelliFlo VF 3.2KW pump, Aquamatic Hydromatic safety pool cover, Autopilot Pool Pilot Digital SC-60 salt water generator. 2 Inch piping throughout.
    donaldm823's Avatar
    Cape Coral, FL
    147
    Re: Best SWG
    I have been thrilled with my autopilot SC-60, now on it's 4th season (new Aug 2007). It maintains the FC at 3-5ppm with ease, running 50-60% 10 hr per day for my 30000gal in ground pool. I just checked the amp-hrs and they were 13000, so I expect 50K or another 3-4years before replacing the cell. Have had no repair issues and I would buy this model again. I do bring the control unit and the cell tree in doors when I winterize the pool, so I eliminate winter exposure.
    I especially like the cell tree that comes with the unit, so that it automatically controls water flow thru the cell via a bypass line and has its own strainer as well as water flow detector/temperature detector, and salt detector. I dislike the auto temperature control of the cell's setting, since when I run my heater, the cell's setting increases above what I need and does not quickly return to the original setting when the heater cycles off. In concept, the auto temp control would maintain the pool's FC better over the season, but since the cell must be on the heater discharge it creates the cell setting isssue. (there is no setting to temporarily turn off the temperature compensation). Here in PA, a heater is needed for MAy and Sept
    Don SW Florida
    10,000 gal in ground concrete pool
    Pentair Cartridge filter, Pentair SWG, Pentair Intelliflow VS pump (11018)
    FAFCO solar panels w/Pentair SolarTouch controller
    using BBB for pool chemistry/Lamotte ColorQ tester for daily testing
