Thread: problem with pump
    May 2009
    Trenton NJ
    497
    problem with pump
    When I turn my pump on for the first time in the morning a squirt of water shoots out of the connection between the pump assembly and the basket. I also noticed, I do not know if its corrosion or salt build up (have a salt water gen.) in the same area where the water squirts out.
    I am also concerned that when I first tried to turn on the pump it did not come on, but did on the second try. Is my pump permanently damaged?
    I also wrote in another post under " Everything Else" I had a problem with losing water, turned out it was the main drain, I ended up shutting down the main drain. Would this be at all related to this pump problem?
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Re: problem with pump
    Does the water continue to squirt out as the pump runs? Is the pump making any new or excessive noises?
    If you could post a picture that would be very helpful.
    Love TFP? Become a
    TFP Supporter!
    May 2009
    Trenton NJ
    497
    No the water only squirts out on start up, on the first start up in the morning. If you turn off and back on after initial start up it does not shoot or squirt water.
    The pump sounds normal,no vibration or irregular sounds. I posted some pictures, you notice some corrosion around where the pump meets the basket. Also water is leaking underneath the basket lid and the plug on the basket. I replaced the rings on both of these last year and also hit it with silicone a few weeks ago.
    I am having a problem uploading a picture - it says that the file is too big (max size is 512 KiB) even though it is only one picture. How do you upload?
    Thanks.
