Thread: Another Aquatrol question
    Hello,
    How can I tell if this thing is working? My set-up:
    Run the pump on low 24hrs.
    Set the Aquatrol@30% output. It seems to "cycle" on for awhile (I can see the bubble coming out of the return), and then cycles off ( no bubbles). I haven't actually seen it cycle back on. Is this normal? When you dial the percantage lower than 100, does it cycle on and off?
    Thanks!
    24' AG Doughboy w/ 5'8 dish bottom, CWII DE Filter, 1.5 hayward 2 speed pump, Aquatrol SWG.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Another Aquatrol question
    That's right; the percentage you set is the percentage of the time the unit runs. So at 30%, it would run for 3 minutes of every 10, or 18 minutes per hour, however it may be divided up. If you sat there and watched it long enough, you'd see bubbles again.
    Thank you. I am losing my mind with this new pool!
