Results 1 to 7 of 7
Thread: Draining Rain Water
    Apr 2010
    Western North Carolina
    44
    Draining Rain Water
    I've read somewhere that some AG pool owners drill a hole in their skimmer just above the ideal water level. So, when the water rises, it simply runs out the hole.
    I have drained nearly 4 inches of extra water in 2 days. It seems like a simple fix but maybe I'm not seeing any potential problems.
    What is everyone's opinion of this?
    24' X 52" AGP - On a concrete slab with 1" Dow blue foam board bottom.
    2Hp 2 speed Waterways pump/Cart. Filter.
    Hard Plumbed 20' away
    Deck 1/3 around pool
    Pool Rover Jr.
    DIY project
    Best Pool Store Quote, "THAT BLEACH WILL DESTROY YOUR LINER."
    22,548
    Re: Draining Rain Water
    That works really well but what works even better is to drill the hole and install a bulkhead fitting and pipe it into the waste line if you have one.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    My skimmer cover has a hole on it, about 1 inch around. Doesn't stop my pool from overflowing during a hard rain...
    Apr 2010
    44
    Bama, that is right on target with what I was thinking. I don't have a waste but I was thinking of adding a fitting and pipe where it can run off without pooling.
    Do you think 1" would do or should it be larger? Also, do you think that I might need a Tee off of the fitting turned up and down. Down to drain and up for a vent so it can get air in heavy down pours. I could cap the top and drill a couple of small holes in the cap on the side for a vent.
    I don't want to butcher my pool but this seems like a good fix.
    What's your thoughts?
    Thanks!
    Pool Rover Jr.
    DIY project
    22,548
    I wouldn't worry about venting it because the top of the skimmer is vented and the drain pipe will be at the top of the water so it can't create a vacuum.
    dorpo75's Avatar
    Jul 2009
    NE Ohio
    256
    Those sound like good ideas. Can anyone post a pic or drawing of what you are describing. I am having trouble visualizing the end result.
    2005 Dimension One Venture model 370 gal. hot tub. We'll be using the TFP method to keep it clean and ready to use!
    TFP - The Finest Phorum on the Net!
    Also have the 1" hole, but with a 30 foot round pool it still takes huge rain to overflow over the wall, I think mine will blow the skimmer cover right off before that happens since I've found it on the ground several times and I've never seen water go over the wall....and if it did...do I care?...nahh.
    i like to keep as much water in my pool as possible living in the country - free water is hard to come by.
