Results 1 to 17 of 17
Thread: Full Print/No Border IG Vinyl Liner?
    Aug 2010
    MA
    173
    Time to make a liner selection for our new pool. We are leaning towards a borderless/full print, but are slightly hesitant mainly because we just have not seen many(or any for that matter). We're wondering if there is a reason you don't see more people choosing this option. Any pics of pool with a full print liner installed as well any thoughts/comments/suggestions would be greatly appreciated. Thanks.
    Completed: June 2011
    18' X 38' IG Vinyl, 3' - 8' depth ~ 24K gallons
    2 skimmers, 2 wall suctions, 3 returns, 1.5" piping
    Hayward Equipment: 1HP Tri-star 2-speed, Aqua-Plus SWG,
    Star-Clear Plus 175 sqft cartridge filter, Colorlogic 4.0 LED
    The Pool Cleaner 4X(suction)
    2011 Jacuzzi J-280 Hot tub
    flyboy320's Avatar
    Jul 2009
    Burlington, Ontario, Canada
    216
    Re: Full Print/No Border IG Vinyl Liner?
    We chose a borderless liner mainly because my wife didn't like the border styles!
    10K gal IG, vinyl, 1 HP Jandy Stealth pump, Jandy CS cartridge filter, Delta UV system, Hasa Liquidator
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by flyboy320
    That certainly is a nice "clean", uncluttered look. I, personally, like the look.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Aug 2010
    MA
    173
    Thanks for the reply and the pic. Beautiful pool! That is the clean, classic look we are hoping to achieve. Is that a solid color liner or does it actually have a print?
    flyboy320's Avatar
    Jul 2009
    216
    It does have a print on it. I'm away for a few days, but when I get back I'll post a closer picture. It's like a mottled look.
    Aug 2010
    MA
    173
    Ok, thanks. I'd appreciate that.
    flyboy320's Avatar
    Jul 2009
    216
    Sorry I haven't had a chance to post a picture, I've been away for a few days on the road...
    Anyways, here is a close up of the pattern of the liner.
    Aug 2010
    Nyack, NY
    35
    Hey, thats a nice liner... Altho, Im wondering if a printed border actually serves a functional purpose of masking a faded area of a liner above the water line once it starts to age?
    I would really like a liner like yours due to it's clean simplistic look, altho, my concern would be that over time, without a patterned border, would you start to see the seperation above and below the water line?
    ~When I was a child I caught a fleeting glimpse out of the corner of my eye.....~
    -Name the song and group!-
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    A tiled pattern will fade just the same as a speckled pattern like flyboy's. It's just a fact of life.
    Aug 2010
    Nyack, NY
    35
    Yes agreed...my point was that a separate tile like pattern above the water that becomes a bit faded may not be as easily discernible against a different pattern below the water that hasn't faded. Its probably much easier to see a faded area vs non faded area when there's just one continuous pattern above and below the water. Perhaps I'm wrong.
    Oct 2009
    3,899
    I was thinking that if you have a tiled border, the portion below the water will fade and the portion above will be darker (chlorine in the water bleaches the liner much more than sunlight on the dry portion). Regardless of what you do, after several years you'll have lighter color below the water line and darker above.
    New2Me's Avatar
    Jun 2008
    SW Indiana
    322
    Here's a link to our liner,
    http://www.troublefreepool.com/ig-li...ir-t13996.html
    and maybe some info you might find handy PRIOR to/DURING a liner replacement. We didn't like any of the liner tile styles.
    22 x 40 IG vinyl lined, 23,570 gal.
    1 hp. Pac-Fab Challenger pump 300# sand filter
    Intex 8110 SWG, Hayward CL220 offline feeder
    Hayward 250K Btu gas heater
    Aquabots
    Aug 2010
    MA
    173
    I really appreciate all the replies and pics. I am now convinced that we are going to opt for a full print liner with a cantilever edge. I'll post pics when we reach that stage. Thanks again.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    The liner we have in our pool now doesn't have a border. We've noticed over the years that a pool that doesn't have a border will "look" bigger vs. the same size pool with a border.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Aug 2010
    MA
    173
    Quote Originally Posted by X-PertPool
    Any pics you could share?
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Quote Originally Posted by mx702
    give me a couple days to dig out the old liner pictures and i'll take some new shots with the new borderless liner.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    Sep 2014
    Milford Ohio
    1
    I am trying to pick a borderless liner and it is a real hard choice-I can't seem to see any of the pictures on the site-can anyone help? Thanks!!
