Results 1 to 8 of 8
Thread: ProTeam Supreme Plus
    Hello,
    Yes, I know this is more expensive than the DIY method, but my pool is 2 weeks old, and will more than likely be closed for the season in two weeks, so I am taking the easy route.
    Seems like this is a great product, but I have one question I am hoping someone can help with. I understand how to figure the correct dosage for my pool, but the instructions on the label state to add the full qty needed in 2 seperate applications. What they fail to state is how LONG do you wait for the second application.
    Anyone have any insight on this?
    Thanks.
    FYI--my current numbers:
    FC 4.5
    CC 0.5
    TA 130
    PH between 7.2 and 7.5
    CYA 50--Adding more this weekend.
    Installing my aquatrol SWG tonight as well.
    24' x 52" Doughboy AP, approx. 15,000 gallons.
    24' AG Doughboy w/ 5'8 dish bottom, CWII DE Filter, 1.5 hayward 2 speed pump, Aquatrol SWG.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: ProTeam Supreme Plus
    10 seconds.
    Really I can't imagine why they say that. The whole point of using that as opposed to the borax/acid route is that it is pH balanced.
    I went the boric acid route and did it all at once.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Thanks for the qucik reply.
    What about how soon to safely swim?
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    I would hold off on adding it this season. You'll end up having to replenish some of your borate level in the spring and I would rather see you work on lowering TA if the addition of a SWG is causing PH rise. Other than that, just borate in the sping
    If you decide to proceed, allow for on full turnover and make sure you test PH before swimming.
    Thanks for the advice. I am set on adding this year, so I will take your advice on waiting for a turnover and PH test.
    ON another note--I was under the impression that the TA was to be left alone if there were not other issues? My PH has been 7.5 consistentaly, expect for the last couple of days it has dipped a tenth or two--I am attributing this to the solar cover staying on the last 3 days.
    The manual for the SWG states to keep the TA between 80 and 120, So I am not too far off?
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    That's fine...I love borates and use them personally, but just figured I would let you know you will need to replenish some.
    Great that TA at 120 was working fine, but I noticed you were installing a SWG tonight and that promotes PH rise...once you add borates, if your PH starts rising it will take more acid to adjust PH down with borates.
    Thanks for your help and input! It is truly appreciated!
    I am somewhat impatient, and would like to get as much done this season as possible. To much type "a" in my blood. I also read the Borates help with a cleaner open in the spring, which is another reason. That and my Dad, who is a pool know it all, is coming up this weekend. I would love for my water to be the best possible for this...
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    You're very welcome Borates do tend to make your water sparkle
