Thread: DIY Heater Reusing A Broken Heater?
    Hey folks,
    I've got access to a friend's Heat Pump that's not working. I was thinking...would it be possible to steal some of the internals for a DIY heater? I'm assuming there's a stainless steel heat exchanger or stainless steel coils inside that thing that's would be $$$ to build or buy. If I can take that and use it in either an outdoor wood stove or in a grill or on top of burners (as seen in http://www.redneckpoolheater.com/ ) it would bring me 90% of the way toward a DIY pool heater.
    Now...I know that this type of heater design is ineffecient. But, I'd only probably use it a few times a year, just to give the water a jolt. And it's better than nothing and much cheaper than other options (other than solar). Long term I might not save money, but I'm ok with that.
    But...back to the main question...what's inside these heat pumps? If I open it up, will I find a reusable stainless steel heat exchanger (or coils) that I could use for this type of plan?
    Thanks!
    18 X 36 In-Ground Vinyl Pool, Hayward 1 HP SuperPump, Hayward SP270T 350lb Sand Filter, CompuPool CPSC48 Salt Chlorine Generator, Hayward H400FDN 400 BTU Natural Gas Heater, 2 returns, 1 skimmer, No Main Drain
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: DIY Heater Reusing A Broken Heater?
    I doubt you'll find what you want. The tubes inside the heat pump are for the refrigerant, not the water. Probably too small for what you want.
    If you're gonna get all creative....
    Guest
    You come up with some funny stuff, Richard! Crazy part is, some folks probably really do that
    lol That's hilarious!
    Ok...thanks for the tip on what's inside the heater.
