I had posted about a problem with my Pool Pilot Digital (SC-48) back in May, when I opened my pool. I noted a "Check Cell - Low Amps" error and indeed there was a problem. After some discussion here, sending the unit back to Autopilot - who told me that after extended testing, they could not find a problem with the unit, I ended up getting a new cell, a new circuit board with updated software, and a new cord to connect the cell. Things seemed fine for several weeks.
A few weeks ago, I noted the dreaded "Red Light" flashing and now I am seeing a different error -- "Purifier OFF! Pwr Ctrl Error". There is no chlorine being generated. When I run the test, I get the following:
Salt 2900 ppm
add 20 pounds Salt
Temperature 85
13V 2.6Amps
04 318 64
or
Salt 2900 ppm
add 20 pounds Salt
Temperature 85
9V 2.4 Amps
04 364 64
I called Autopilot and they told me to send it in and they would take a look. I suppose I don't have any options, as there is no dealer nearby.
Just wondering if anybody here had any thoughts. What do the numbers "04 318 64" or "04 364 64" (which appear at the end of the test) mean?
Thanks
Salt 2900 ppm
add 20 pounds Salt
Temperature 85
13V 2.6Amps
04 318 64
or
Salt 2900 ppm
add 20 pounds Salt
Temperature 85
9V 2.4 Amps
04 364 64
Thanks
