Thread: Using Winter Pool Cover Bigger Than Pool Size
    I have a 15' foot, but between the bubble and decorative caps, the 15' cover does not fit well. Another foot or so would make things so much simpler. Is there any harm using a size larger other than cost? Thanks.
    11000 gallon Viking Fiberglass 12 x 28, Intellichlor IC-40 SWG, 24" cascade fountain, 12" cascade fountain, 1 1/2 HP pump, sand filter
    22,544
    Re: Using Winter Pool Cover Bigger Than Pool Size
    Nothing wrong with using a larger cover then the size of the pool. Makes it easier to anchor it over the walls.
