Results 1 to 8 of 8
Thread: Pool Deck Concrete Question
    I just had my pool deck finished today. I went with the basic concrete that has a nice design, going out a bit on certain areas. They did a trowel finish instead of a broom finish.
    When it's wet... it's a dark gray and I like it. To my surprise today... it dried and became almost white!!! Whoa, it's bright. It's so light. My husband says it will darken up over time... but how much time. I'm not sure I like it. It is so bright and ghosty. I was hoping for it to be on the more tan side. But they say the tinting is expensive... it wasn't in my budget.
    Am I living with this for years? Anyone have any experience.
    76549 Liters -- Cartridge Filter -- In Ground -- Vinyl -- TF-100 Test Kit -- AquaVac Robotic Cleaner -- UV Sanitation -- Winter Safety Cover -- Installed 2010 -- Southwestern Ontario, Canada
    Latest Test Results June 25:
    FC - 6, CC - 0, CYA - 40, CH - 110, TA - 90, pH - 7.5
    Re: Pool Deck Concrete Question
    I wonder about this too. As part of a renovation, the pool deck was redone in April of this year. In June, the satellite imagery for Google Maps was updated for our area. WOW, you can see it from outer space
    1973 23,000g Sylvan Kidney
    Plaster with Aqua Bright (EcoFinish)
    Hayward DE4820 Filter, 1 HP Hayward SuperPump
    Piscataway, NJ
    Guest
    Newer decks will take an acid stain pretty well. You both might look in to that.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    It will certainly darken over a year or so, just like sidewalks, driveways etc. Tan cement is tinted tan and is more expensive. White cement is also more expensive, so I doubt they used that too. Light gray = new cement
    Apr 2010
    Buckeye, AZ 85326
    619
    You can buy concrete sealer that will give you that wet look you desire. The contactor that poured our landscape curbing suggested it. I just havent got around to it. Plus it seems it will be a yearly expense and maintenance item.
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    Aug 2010
    Houston, TX
    14
    There are lots of concrete stains on the market. Sherwin Williams is a good place to start:
    http://www.sherwin-williams.com/do_i...oncrete_stain/
    I'm betting that Home Depot or Lowes might have some in stock as well.
    IG, Peb Tec, 15,000 gal saltwater pool with spillover spa. Pentair Clean and Clear Plus cartridge filter (flow rate 150 gpm). Pentair WhisperFlo 2hp pump + 3/4 hp booster pump. Intelichlor IC40 cell. UltraPure Turbo Shock ozone generator. Pentair 320 in-line feeder for winter chlorination. StaRite Max-E-Therm nat gas heater. Pentair EasyTouch controls
    Guest
    Had a customer buy a pool that I built one time and order San Diego Buff (pretty sure it's a Davis color), and after decks were poured it was obvious somebody goofed! It was natural concrete, and the deck man never got the info, so he assumed it was natural. It was not his fault, but he said that he had heard of a stain that might work, and if the homeowner was willing to try it (and was satisfied in the end) then he would give it a shot.
    It is still probably one of the most even looking colored concrete jobs I have ever seen. The stain worked perfectly, it was not blotchy in the least and it was (is) absolutely gorgeous still to this day.
    I'm not sure that you could expect the same from existing concrete, but fresh stuff should take pretty well, as it is still curing out (technically, concrete takes 40 years to fully cure, I'm told!). And, because it is a stain, it should hold, as it will enter into the concrete, not sit on the top.
    Does anyone have any experience in acid staining? Does it hold up? Or is it something you have to maintain every couple years??
